Oil residue
Old 01-12-2011 | 01:29 PM
Default Oil residue
Well I was replacing the battery on my 08 Silverado and found some oil residue on the valve covers. Should this be of any concern to me? Truck is bone stock minus lift and exhaust.
Old 01-12-2011 | 02:08 PM
iamkeniff's Avatar
where is it located? by the bolts? the filler tube? by the seal the goes to the top of the head?
Old 01-12-2011 | 02:29 PM
Its more around the seal on the top and bottom of the valve cover.
Old 01-12-2011 | 02:48 PM
Daryn's Avatar
Formerly darynC-10/23/10
i would say its semi- normal , if your **** about having oil everywhere. you can change the rubber gaskets on the valve covers. that would keep it from leakin .also when they are off spray your bolts with carb cleaner. should make the rubber swell up
Old 01-12-2011 | 03:37 PM
I'm not really **** about it just wanted to see if anyone else had this problem and make sure nothing was wrong. This truck is my daily and only vehicle. Thanks for the comments!
Old 01-12-2011 | 03:48 PM
Daryn's Avatar
nah just a ls thing
Old 01-12-2011 | 08:04 PM
iamkeniff's Avatar
along with the famous "cold start tap"
Old 01-12-2011 | 11:40 PM
Mrgoodwrench3's Avatar
Well I am overly **** so I would remove the gaskets and replace them.
Old 01-13-2011 | 05:37 AM
iamkeniff's Avatar
you do have a VERY clean engine bay
lukn4trbl355
10-21-2015 11:19 PM
sTNT971
09-26-2015 04:22 PM
lxcoupe
09-25-2015 12:36 PM
69z-28
09-21-2015 07:31 AM
Velocity1
09-15-2015 11:29 PM
Quick Reply: Oil residue
