Procharged Again!
Procharged Again!
As the title states, I'm about to be procharged again . I liked the D1SC on my last truck and I've decided to go that route again.
Does anyone know the limits of the Flex Fuel system?
I am looking for a set of injectors that are a direct swap, possibly the ones from the House of Boost????
Opinions are welcome!!!!
I'm at 8lbs (on a maggie) on the non-flex pump and still have safe fuel pressure at WOT, so on the flex pump maybe 10-12 (purely guessing on my part using my setup as a reference). I'm positive someone here has found the limit of the flex pump and can answer more specifically though.
*EDIT: Should ask however, what engine size? 5.3 or 6.2?
Flex fuel injectors I believe are somewhere around 35-38lb/hr, so you'd still want to change them if you're going with ~8psi. I have 45lb/hr ones and wish I would have went with 52lb/hr ones.
If you're keeping the stock intake, you want the tall style USCAR injectors. Might as well get 60s and leave some room to grow.
