Procharger 6.2
Old 03-09-2012, 05:34 PM
  #21
How much did that kit run? How was the install; did it require permanently modifying anything (hacking up parts of the truck) or can it be put back to stock if needed?
Old 03-10-2012, 06:36 PM
  #22
gonzo 6.2's Avatar
any track times?????
Old 03-11-2012, 03:04 AM
  #23
11 Second Hall Moniter
AKlowriderZ71's Avatar
You mentioned maxed out injectors. Which injectors are you running?
Old 03-11-2012, 05:39 AM
  #24
ak2007r6's Avatar
+1
Nice truck. Curious what your new times at the track will be.
Old 05-06-2013, 11:01 PM
  #25
james8997's Avatar
Track times?
Old 05-07-2013, 01:42 AM
  #26
JCunningham's Avatar
you should be making more then that at 10psi. and ya what injectors. if stock your not making 10 psi. they cant handle 10.
Old 05-07-2013, 01:52 AM
  #27
Why do you say that? They can & have been just fine on 10 psi and more. The fuel system and the tune has to be right.
Old 05-07-2013, 02:00 AM
  #28
because im running stock injectors @8psi and they are @98% idc and 2 tuners have told me no way they will handle 10psi. What IDC would they be at 10psi? Im getting a dyno tune thursday and if I could do 10psi on the factory injectors and fuel system I would.
Last edited by JCunningham; 05-10-2013 at 09:21 AM. Reason: they are not at 84 there 98
Old 05-07-2013, 02:04 AM
  #29
His PC would have came with 65# injectors.
Like I said, the fuel system and the tune both have to be right.
Old 05-07-2013, 04:02 AM
  #30
ak2007r6's Avatar
His kit would have come with the FAST 65# injectors but if he says he is maxing out his injectors it makes me think he has not upgraded them. With the 65# injectors he could more than handle 10#.
Needs a boost gauge, curious what it's actually seeing.
Quick Reply: Procharger 6.2
