Pulled The Trigger...
#63
Found my answer
For those of you following, I got up with 21st Century Motorsports. Here is what he sent me:
"Hi Steve,
The motor is stock, the transmission was built by Circle D in Houston .
The tune is basically stock but has a transmission tune from Circle D
The internals on motor is stock
Best Regards,
John Page
Twenty First Century Muscle Cars"
I would guess Circle D wouldn't throw in a trans without a stall though, huh?
"Hi Steve,
Best Regards,
John Page
#66
If it's pulling on you at 1800 it probably has a stock stall. Most aftermarket converters will start mid 2k's if not higher. On the TBSS's, it's usually 2800-3600 depending on what you get.
As for AWD dyno's, T1 in Rowlett has one, as well as Kan Tuning in Lewisville. Kan usually does imports, but was running a GM special a while back. There are a TON of good tuners locally, so do your research and meet a few.
You don't have to get a dyno tune, either. A street tune could prove more practical in the long run... or a dyno tune to get it squared away and then street tune for fine tuning.
ADM performance, Kan Tuning, & HPP are all in Lewisville
LG/GSS are in Wylie
True Street is in McKinney, IIRC.
You could also do a mail order tune like PCM4less, but you won't have the local convenience.
LG/GSS are in Wylie
#67
This is what I got from Circle D Specialties about the stall.
"I assume that is the 6 speed transmission. It looks like I built them a 265mm 10.5" multi disk. It will be a fairly tight stall, probably about a 2500 flash RPM. You need to contact Circle D Trans for that info. A phone call works well for them -713-895-7019.
Chris "
It has a stall, probably I was doing the test wrong. They have invoices on my truck, and he only took the engine and brakes.
Chris "
#68
LG/GSS are in Wylie
LG/GSS are in Wylie
To the others wondering if I ever got my lower grille... I did. The dealership said they knew nothing about it, but bought it for me with little to no debate. I will go to Home Depot to grab some liquid nails to put on the inside of it, so it goes nowhere!
