Question on dod delete
Old 02-09-2013 | 07:03 PM
oneslammedgmc's Avatar
Default Question on dod delete
I've got a nnbs 07 rcsb 4x4 silverado with a 5.3. I'm considering lowering it and installing a set of headers, having a local shop do the cam swap along with a dod delete. My question is, how much should I expect to pay to have the heads pulled to do the dod delete? Also, my truck is an automatic, would I most likely have a 4l65e tranny or what?
Old 02-09-2013 | 07:36 PM
iamkeniff's Avatar
75 to 100 an hour labor not including parts.
4L60e which is the same as a 65e except for a few more hardened parts in the 65e
Old 02-09-2013 | 08:00 PM
I guess my main question would be how many hours does it call for to swap the head gaskets on the truck, so I can figure out a price.
Old 02-09-2013 | 08:24 PM
iamkeniff's Avatar
It takes 1 person 6-8hrs...now being a shop they go by the book so your best bet is to call them to see. Be ready for a 1200-1900 bill
Old 02-10-2013 | 01:12 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Mitchell shows 11.7 hours labor for replace all lifters. Hope that helps!
Old 02-10-2013 | 02:24 AM
iamkeniff's Avatar
Then you add in valve seal hour, add in cam removal hours. Shi is gonna add up fast unless you find someone to do it on the side for a set price
Old 02-10-2013 | 12:12 PM
There's a local speed shop that I would take the truck too. They're usually pretty reasonable on work and perform dyno tuning as well.
Old 02-10-2013 | 12:35 PM
AUTOT3K's Avatar
Shop key for cam shaft is 24 hours??? Wow.
Heads are 9 hours.
So budget for like 12-15 hours by the time your done
Old 02-10-2013 | 02:07 PM
iamkeniff's Avatar
If you was closer id do it
Old 02-10-2013 | 05:40 PM
AUTOT3K's Avatar
I'm on mobile. . Wheres the op at? I'd be willing to do a cash job too!
Quick Reply: Question on dod delete
