Rear block removal
#32
I had one of my sales guys call the stealership yesterday to get those NBS 2wd u bolts (PN 15002781) and the parts guy said not a valid number.
Just to verify, i just need the ubolts from a 99-06 halfton 2wd for a factory appearance after block removal? Regardless what the number is, I will get it figured out.
#33
So instead of having one of my monkeys call, I called the parts dept. They gave me three numbers :
11589202
11518875
15734233
I used a 2004 1/2 ton 2wd as the vehicle. They didnt have any on their shelves, so i can not verify size of any of them.
Any body actually work at a stealership in the service/parts that can verify which one is correct?
I could use Ubolts off my shelf, but i want it to look factory.
11589202
11518875
15734233
#34
wow hmmm ill have to dig up the receipt from the dealer and see what it says.. you should be safe getting 2002 1/2 ton 2wd u bolts.. the torque spec is 74 ft lbs thats what i used... sux about not having any luck...
i just googled PN 15002781 and it brings up several forums and what not about them.. only thing i can think of is maybe it got updated to a new number..
Last edited by that dude named guy; 01-20-2012 at 03:05 AM. Reason: goooooooooooogle
#35
74 ft lbs is what my Haynes manual told me to use.
#36
I just pulled my rear blocks this afternoon. I re-used the original Ubolts, I just added 3 9/16 flat washers per nut (so total of 24). 3 washers each was probably overkill, but i wanted to make sure i didnt run out of thread. Dropped it 1 1/4 in the rear. Sits way better now. Now i need to paint my rear wheel wells black. Since my truck is white, the white bed sides exaggerate the fender to tire gap.
#37
Gm sells some really nice plastic rear liners around $100.
Just seen them in person last week and now they will be on my truck very soon.
#39
#19166676 = Silverado
#19166677 = Sierra
GM Parts Direct: Your direct source for Genuine GM Parts
#40
Intend to get a pair for mine as well.
#19166677 = Sierra
#19166677 = Sierra
