Rear suspension noise
Old 03-30-2013, 04:13 PM
Vdrsnk04's Avatar
Default Rear suspension noise
Well before I explain my issue ill let you know a little about the truck. I own a 2011 sierra denali AWD. I bought it new in 2011 and it has 15000 miles right now. Right after I bought it I installed blistein 5100 shocks all around it. Well this week I just ordered 2" drop shackles and hellwig sway bars for front and rear. I would like to figure out my issue before I put these new parts on if possible.
So now that all the info is there this is my issue. Wednesday my wife and I were going to dinner and noticed when we pulled out of the driveway that once the rearend hit the bump that it made a clunk type noise and sounded like something was loose. I pulled out of the driveway going forward and turning left. Fast forward to today and I used a speed bump and took all four tires over the bump singaly. Now, each time I take the right rear tire over it in any way it makes that exact noise. So I took it to my garage to inspect, I really found nothing, I tightened every nut and bolt imaginable back there and my rims. Still the same issue.
Any suggestions for what to do?
Old 03-30-2013, 08:53 PM
SLCviaAK's Avatar
If everything is tight, and nothing is broken, try greasing between each leaf. See if that helps.
Old 03-30-2013, 08:57 PM
joshua022's Avatar
Nothing in the bed right???
Old 03-30-2013, 09:53 PM
Ignore it these trucks make noises once they get some miles that's why they are trucks and not cars. Mine has the exact same noise since day 1 it's the springs.
Old 03-31-2013, 10:02 AM
Vdrsnk04's Avatar
Ill give it a shot.
No, just some straps.
I disagree on its because its a truck, none of my trucks have done this. Also, if that's the case I won't be keeping this truck lol.
Maybe ill call the dealer since its still under warranty.
Old 04-01-2013, 12:19 AM
AUTOT3K's Avatar
check to make sure those little plastic "discs" between the two bottom leaf springs didnt fall out
Old 04-01-2013, 05:06 AM
Vdrsnk04's Avatar
I'll take a look. I didn't know that there were plastic discs between the two bottom leaf springs.
Old 04-01-2013, 06:48 AM
VegasJ's Avatar
hmmmm.... not trying to thread jack, but since I put on my new shocks and DJM flip kit, something in the rear pops or clunks as well.
But only when I hit a bump AND turn left while doing it. I've checked all bolts and they are tight too. Maybe I should try the greased up leafs...
Old 04-01-2013, 09:34 AM
Vdrsnk04's Avatar
Sounds like my ordeal except turning right. Ive had my shocks on for almost 2 years now though so you wouldn't think the shocks would just start to act up now.
Old 04-06-2013, 09:14 PM
Vdrsnk04's Avatar
Well guys, I have figured it out. I went ahead and installed my drop shackles tonight. My friend and I got them on in about an hour, then took my truck for a drive before reinstalling the hitch. I drove my usual route to work and to my surprise the truck never made the normal sound once. So, I am guessing it must have been the stock shackles, possibly the rubber bushings had an issue.
Quick Reply: Rear suspension noise
