school me on HIDs..mine are flickering
heres the scoop ..when i bought my truck it already had HID lows and the fog lights...well now ive noticed that my RUNNING lights are flickering and some times the pass side doesnt even turn on...but if i turn the headlights on they both turn on and stop flickering
and just noticed one of my fogs isnt coming turning on
as far as the fogs..is there anything i can check to see if the bulb is burnt out? not sure on the life span of HIDs maybe il get lucky and its just a loose wire lol
A nice benefit of pulling the DRL fuses is the lights won't come on in the daytime, so you're saving over half the bulbs lifespan by not using them when you really don't need them.
Quickest test for the bulb is to switch it from one side to the other and see if it still doesn't ignite, just be careful not to touch the bulb with your bare fingers.
When my HID's flickered and or the Pass side would not come on i installed a relay harness. Problem went away. Not sure if this will help a DRL problem.
carhidkits dot com/hid-kit-wire-relay-harness-w-flicker-plugs-275.html
