Shackle drop questions
I am new to the board. I bought my 12' Silver ice met crew cab about 6 months ago. I just installed the Belltech 2" drop shackle kit #6401 with the ubolt to remove the rear blocks. The Install went smooth and the truck rides great however the rear is now lower than the front. I installed the drop shackle at the 2" drop setting and removed the rear block? I'm measuring about 3/4" lower in the rear. Should I put the rear block back in or move the shackle to the 1" drop setting with the rear block out. Any advice would help. Thanks
I had that same thing, before lowering; my rear was only 2" higher then the front
I also did drop struts so my 1" in the front and 3" in the rear is almost dead level.
so to answer your question, either put the block back in, or get some drop struts and lower the front!
Thanks. I'll give this a shot. I am going to end up lowering it more with a nice set of sways but for now I at least have to be level. I'm not a big fan of the Cali lean.
Right on. I'm the same about cali stance. But you said "lower it with sways" the sway bars won't lower it unless I read that wrong haha
