Started 6l80 tranny swap today
Old 06-18-2016 | 06:28 PM
  #41
motohead911's Avatar
As for all the splices I soldered and wrapped them. All the connections are hidden back under the plastic cover. All but one were easy to figure out. The fuel pump connect on the new harness had two GR/WH wires while the old one had one GR/WH and one YE/BL. I found were the yellow one went and then figured our which on the two green wire went to the same pin location in the ecm connector.
Old 06-18-2016 | 06:29 PM
  #42
Originally Posted by Wolftrk99
Did you have to manually enter the vin for the tcm into tis2web/sps?
Yes you have to manually enter the vin.
Old 06-18-2016 | 06:35 PM
  #43
Wolftrk99's Avatar
Good to know, im sure i will have more questions when i get around to getting my trans built and in.... Kinda more worried about engine swap first.... Although considerig i am adding vvt and having to change harness anyway, probably be better off swapping both in at same time....
Old 06-18-2016 | 06:36 PM
  #44
Wolftrk99's Avatar
What cable did you use to prgram it??
Old 06-18-2016 | 06:39 PM
  #45
I purchased a Drew Technologies Mongoose Pro II GM cable. Then I downloaded the Tis2web on my tablet.
Since you are going with a vvt motor you could just order a harness from a denali 2wd from your year and it should just plug right in.
Old 06-18-2016 | 07:07 PM
  #46
Wolftrk99's Avatar
I have an 08 yukon thats 4wd with autotrac, and ive got a harbess from an 11 sierra thats got a couple harness bundles cut(fuse box and i wanna say the bundle for the passenger side o2 sensors going by the a/c stuff...) and another harness from a 2007 denali... Just not sure if its 2 or awd....wanna say by vin on tag it came with its awd,need find it again...
Old 06-18-2016 | 07:14 PM
  #47
Wolftrk99's Avatar
Wow.... Just looked up the mongoose cable.... I can get an mdi for a fraction of the cost of mongoose cable....or i can use one from work. Where did you get yours from?
Old 06-18-2016 | 08:59 PM
  #48
Tuner tools. I went with the Mongoose because it is certified to use with gm software, and the tech support if I needed it.
Old 06-19-2016 | 01:25 PM
  #49
Ok here is a parts list I used for my swap
Transmission. 19328910
Cooler lines. 25999419
Filler tube. 24260606
Filler tube seal. 15796802
Wire harness. 20822437
Oil indicator. 24267668
Heat shield. 25980339
Bracket for
Shift cable. 15831435
Lever trans
Shift shaft. 15915996
Vent hose. 24256930
I also needed to buy a slip yoke. I can't find the part number right now, but I just ordered it from the Chevy dealer.
Old 06-19-2016 | 06:16 PM
  #50
Wolftrk99's Avatar
Have you tried reflashing your bcm yet for the tu/td?? I was digging around my yukon today and everything is already wired up for it....
Quick Reply: Started 6l80 tranny swap today
