Started 6l80 tranny swap today
Old 06-30-2016 | 09:54 PM
  #61
Wolftrk99's Avatar
What mechanism did you change in the column?
Old 06-30-2016 | 10:31 PM
  #62
motohead911's Avatar
Originally Posted by Wolftrk99
Splain lucy!!! Was it just changing the d4 to d5? Or did you have to do anything with bcm
Yes I changed the enable to D5. I also ending up reflashing the BCM with an 07 2500 VIN. After I did the the TUTD started working.
There is a little more than just that but I will right it up later tonight.
Old 06-30-2016 | 10:48 PM
  #63
Wolftrk99's Avatar
Sweet!!! Good job, congrats!!! Details please, youre my hero for proving my theory right!!
Old 07-01-2016 | 02:16 AM
  #64
Here is the latest. It has been a long day. It started with me thinking I bricked my TCM after trying to load an 09 tune. It stopped communicating and shifting. It took me a long time and about 10 different tries with SPS. I finally got an 07 Denali tune to take on the TCM.
After the trans was working again I started in on the BCM. I flashed an 07 2500 tune into the BCM and was able to get the TUTD functioning. But it locked the radio and I lost my remote start. I was able to use SPS to unlock the radio, but I still haven't figured out the remote start.
After I got the TUTD functioning, the ecm was still throwing a code for a crank relearn. I reflashed the ECM and TCM tonight with the tune I had before this morning's fun. I was then able to do a crank relearn and the DTCs are gone.
So right now I have 4 different VINs in various controllers on the truck, and they all seem to be playing nice.
Where I go from hear, is I need to send my new cluster out to get the hour meter and odometer to match the old units since it is a junkyard take out. I also need to work on my TPMS. The DIC says it needs service. Lastly, I would really like to get my remote start working again.
Old 07-01-2016 | 02:25 AM
  #65
The shift mechanism that the shift lever attaches to. FYI, if you change it, you will need to remove the lock cylinder to remove the interlock.
Old 07-01-2016 | 03:57 AM
  #66
Wolftrk99's Avatar
What was the reason for changingit?
Old 07-01-2016 | 07:45 AM
  #67
Wolftrk99's Avatar
With your remote start not working did the vin you used for the bcm have remote start, that may be the problem with that!!!
Old 07-01-2016 | 12:47 PM
  #68
Well I have been doing some more work on the truck this morning and I still haven't been able to get the remote start to work. I tried a different flash in the bcm and still didn't have the remote start, but I loss the TUTD. So I had to go back to what I had before. Oh well. Maybe at some point I will work on the remote start again, but for now that is a small price to pay to gain the transmission function. On a side note the TMPS is working but all fours tires are reading 6 to 7 pounds hire in the DIC then on the pressure gauge.
Wolftrk99 to answer your question, I changed the actual shift mechanism because I was thinking that maybe M mode was in a slightly different location then either 3 or 2 on the 4 speed shifter. Its not so your really don't need to change it.
Once I get my cluster back and installed my swap will be done and it will look like a factory install except for the trans cross member. And since I got almost all the parts from GM they all have a little bit of a warranty. Yippee.
Now I need to do is fine tune the trans.
Old 07-01-2016 | 02:21 PM
  #69
Wolftrk99's Avatar
What are the vins for that youre programming the bcm with, i have a vin for an 07 denali, that may be able to get you tu/td and the remote start working again.... I pulled the build sheet/rpo list on it and its damn near identical to my yukon save year and engine trans combo....
Old 07-02-2016 | 11:11 AM
  #70
I think I will just live without the remote start for now. My XM module is also locked. I called XM and they said take it to the dealer. From what I researched, the module is VIN locked so I might need a new module so
it can marry up to the new VIN.
The PRNDM cluster has been shipped out, and when it comes back and gets installed I am pretty much done.
I will go back and revisit the remote start and XM but later this summer.
Quick Reply: Started 6l80 tranny swap today
