Steering wheel noise really odd...
Old 10-18-2014, 04:19 AM
  #21
Registered User
2008silverado's Avatar
Originally Posted by Jordan927
Congratulations.
Just trying to help dick wad...not everyone has a bunch of useless tools laying around
Yeah, all these forums have tit useless m*r*ns trying to help by recommending the obvious things that 1) everyone knows (screwdriver tip), 2) are useless (spraying armor-all inside the column), 3) irrelevant (applying repairs from inapplicable vehicles) and suggesting repairs that worked on antiques of a different design.
Congratulations.
And for the record, the "heavy spring" you call it, that's the upper bearing preload spring. Its in all tilt columns to provide a steady pre-load on the shaft bearing in all positions of the steering wheel. Without it the steering column would flop or bind depending on the position of the tilt.
Think someone with a stethoscope would know that.
Really? Did they "pre-load" it or actually "over-stress" it? Clearly the bearings cannot take the stress of the pre-loading.
How did that happen? It's because auto engineer designers are at the bottom of the engineering food chain, especially those at GM. Instead of making repairable assemblies, they start with a core assembly and they stack, tack and hang a dozen other sub-assemblies on and around it as after thoughts. The result is, you have to disassemble a dozen sub-assemblies to get down to the key components that they UNDER-DESIGNED to begin with.
I have worked with Auto engineers and they just get the junk out-the-door and rely on 10,000 auto forums for people to discover the repair info they refuse to share with customers.
Congratulations.
Dick
Nice applicable signature.
PS: Did you grease the bearing and race with the proper grease?
No, I poured sand all over it and seated the inter race with a 20 lbs sledge hammer.
Old 10-18-2014, 11:13 AM
  #22
Jordan927's Avatar
Originally Posted by 2008silverado
Yeah, all these forums have tit useless m*r*ns trying to help....
Clearly....Case in point ---VVVVV---
Instead, I removed the top and bottom steering column covers and put some sound dampening foam....
The next assembly down the shaft is the Tilt Wheel Universals, but I'm not going there.
That's is an intermediate shaft...it slides out after you remove two bolts. It also has a TSB for the bearing.
Corvette454l88
09-01-2016 01:24 AM
black00chev
08-28-2015 03:39 AM
lxcoupe
08-22-2015 08:23 AM
Ketis
07-23-2015 12:37 PM
lxcoupe
07-08-2015 05:49 AM
Quick Reply: Steering wheel noise really odd...
