straight ethanol performance?
Up here in Canada they dont sell 100% eth anywhere that Ive seen but last weekend I drove to NYC and noticed it at practically every gas station. I wanted to try a tank out but being on the road and far from home I opted not to. Just wonder what anyone thinks of it in stock flex fuel trucks? Worse/better/same power?
When i had my 11.6:1 406 in my EL Camino i ran E85 in it and then retuned and rejetted it for 93.. Way better performance on E85..
But then again i just measured gas consumption in the meano by fun per gallon..
the throttle in that thing is just a switch.. OFF or ON!!!!
Performance should be the same on E85 as premium. Since the max power rating for the 6.2 trucks is 403 on 91 octane, it is unlikely you will gain anything by running anything with a higher octane because the truck has no factory tuning to take advantage of it. If they had timing tables set up exclusively for performance on E85, then the peak power wouldn't be rated at 403hp on 91. It would be rated at 4xxhp on E85. On a factory tune you WILL lose mpg on E85 for sure.
If you have a 5.3 there are two seperate sets of tables; 1 for E85 and 1 for 87. You will gain performance and lose fuel mileage on E85. A 6.2 truck also has two sets of tables. 1 is for 87 and the other for 91. On 87 you lose performance and mileage. On 91 you have 403hp and optimum mpgs. On E85, you have the same power as 91 but you will get lower mpg.
tuned for 91 vs tuned for e85. e85 is faster.
there are tables for gasoline, adders, and wot afr vs timing tables. same goes for e85. part throttle timing does not change. there is not a table for 87 octane. you are confused with the low octane tables. the ecm resorts to this under high knock issues. after so many key cycles it will flip back to the high octane table. the ecm can not tell what octane you put in the truck. it can see the alcohol content and adjust the stoich accordingly.
i myself run e85 in my truck. the torque difference across the board is far greater than pump gas.
