Stroker 5.3
Old 01-01-2010 | 02:02 PM
07silveradoss's Avatar
Default Stroker 5.3
Hey guys i was wondering if i can put a 383 stroker kit in my 07 silverado 5.3 afm.
Old 01-01-2010 | 03:18 PM
iamkeniff's Avatar
yep
all you need is a 383 stroker kit for an LS1 bore your block to 3.905" an run a set of 243s/317s an you have a pretty strong engine. a guy on LS1truck is building one. i have an extra block im thinking of doing that to if i dont decide to buy a stock 6.0
Old 01-01-2010 | 03:21 PM
iamkeniff's Avatar
if you have 799s on your 5.3 now you can use those too. same head flow as the 243s just a different casting number. if you decide to go 383..do a build thread an maybe we can get rid of the constant threads asking if its possible to do a 383 with a 5.3 block
good luck
Old 01-01-2010 | 04:04 PM
norris_83's Avatar
just make sure to use a 58x reluctor wheel crank with the install as well as a 4x sensor cam sprocket (LS2-LS7).... or else you'll run into problems later on..
Old 01-01-2010 | 04:21 PM
dirt track racer 81's Avatar
Thats what Im building now is an iron 383..
Old 01-01-2010 | 04:35 PM
iamkeniff's Avatar
he can use his 58x ring huh or is that kind of a 1 time use? i dunno anything about that...i wanna build a LS3 block into a 427
Old 01-01-2010 | 05:43 PM
viciousknid's Avatar
Where's the Beef?
Curious to know if you can get the LS1 383 kit with a 4" bore and pop it into a 6.0? Certain rod length you would need?
Seen a 4" bore 4" stroke kit for the 5.7 ls1 and thought about maybe putting it into a 6.0 for a SB400.
Old 01-01-2010 | 08:43 PM
iamkeniff's Avatar
get with Someone from TSP an im sure they could tell you..thatd be awsome!
Old 01-01-2010 | 10:12 PM
4 in bore for ls1?
Old 01-01-2010 | 11:02 PM
Where's the Beef?
Originally Posted by dirt track racer 81
4 in bore for ls1?
Sorry. 07 silveradoss. don't mean to hijack.
But yes it was advertised as a 4"/4". I had a ? about it too since I don't think they can go over like a 3.905 or so.
I have seen a few places offering 4" 4" applications so I'm going to tuck that info away for the future.
Quick Reply: Stroker 5.3
