struts
Old 03-10-2012 | 01:21 AM
1badavalanche's Avatar
Default struts
I got my truck where I want it... **** load of power, stance, wheels.. Does anyone make adjustable front struts? She sags around hard cornerings. I need adjustability.. Please help.
Old 03-10-2012 | 01:26 AM
FrankyRST's Avatar
BELLTECH SHOCK ABSORBER, 07-11 P/U & SUV (2/4WD) -2"/+2, SP LOWERING AND LIFTING STRUT - shock absorber - Strut - Products
Old 03-10-2012 | 02:44 AM
lady3bglover's Avatar
Franky...
Do you have these installed?
Old 03-10-2012 | 03:20 AM
FrankyRST's Avatar
Yup, did a 4/7 drop (spindles, springs, flip kit) on my nnbs n it ended up being just a bit higher in the back. Used the struts to raise up the front about .5" to level it out. I really like the struts, it rides a little stiffer which I like and takes corners a little better. Money well spent if you ask me.
Old 03-10-2012 | 08:23 AM
I have the 2/4 Beltech drop on my '02 ECSB since '07ish, with Nitro2 shocks in the rear. It's getting time to chg out, and I'm starting to do my hw. Any other suggestions?
Old 03-10-2012 | 09:56 AM
Hey Franky..... I have installed them last month and after adjusting the height I wanted it still rubs... I have a 3/5 drop on my avy... I need more compression and rebound adjustability...
Old 03-10-2012 | 12:58 PM
FrankyRST's Avatar
What tire are you running? Hows your alignment? What parts did you use for your drop? I hardly ever rub even with 24" rims, it used to rub a little but thats because my alignment was off.
Old 03-10-2012 | 01:46 PM
Yeah Franky, I have 24” and running lexani tires... I found out lexani tires run a bit bigger and wider... So my 295's is actually 305... But still looking for gud adjustibles....
JordanH
02-28-2017 07:22 PM
BCraven1018
11-02-2015 07:18 AM
vmaxpro
09-21-2015 06:46 PM
smit2732
09-09-2015 03:36 AM
Quick Reply: struts
