this thing is a slug off the line...
Old 12-29-2012 | 09:18 PM
  #21
BLACKND's Avatar
higher stall Tq Converter would be the best bang for the buck short of forced induction.
That being said, you do have quite a bit going against you. First, you have the 4.8L and its and Extended Cab, you are running 22's which are heavy as hell and a large rotating mass, and though it might be a small thing, I personally think you are doing yourself a huge dis-favor running true-duals with the 4.8L.
I never had much power off the line when I had my 07 4.8L and it was a RCSB and had 3.73s
If you just want to spin the tires, the stall should help, but also remember, seems like the throttle body operation in the 07's were pretty slow to open.
Old 12-29-2012 | 09:21 PM
  #22
62nalide's Avatar
Originally Posted by amanuel
Would it be better for him to hold off on a cam until he goes forced induction? Idk but I thought that there are cams designed to be optimal with supercharged applications (I assume that's the route he'll take) n/a or turbo applications.
Does your truck have VVT? I know I've seen quite a few people more knowledgeable than I condemn utilizing VVT when "camming" ones vehicle but it seems to me that it would help with low end power more than a nonVVT.
I agree with what most everyone else said- 3200 stall. You won't regret it
Idk much about it but I read a few things here and there and the consensus seemed to be that Underdrive pulleys don't really do much. Probably not as useless as a throttle body spacer but I believe one person actually grouped those 2 together when talking about their use.
Correct me if I'm wrong on any of that.
Some say no some say yes, we netted 6rwhp on a dyno might not be a big gain but a gain is a gain
Old 12-29-2012 | 10:58 PM
  #23
nighthawk08's Avatar
3000 stall was the first mod I did to my 4.8
the no low end is mostly caused by the slow throttle body, the stall helps a bunch!
Old 12-30-2012 | 12:34 PM
  #24
0black24sierra7's Avatar
ok cool, thanks for all the help/advice guys!!
Old 12-30-2012 | 01:11 PM
  #25
03sierraslt's Avatar
That and a heavy truck with a small motor.
Jordan927
11-10-2015 02:47 AM
Lthompson
09-21-2015 07:06 PM
lxcoupe
09-21-2015 11:53 AM
xtrooper89
09-21-2015 06:03 AM
Quick Reply: this thing is a slug off the line...
