Tire Pressure Monitor
Old 08-13-2008, 03:18 PM
bowtieguy79's Avatar
Originally Posted by circusboy
you first have to open the door, set in the truck and close the door, turn the key to the on position grab your nuts for 7.8 seconds, then put the vehicle in neutral, pess the parking brake, turn the radio on, jump out of the truck, run around the truck 2 times acting like a monkey and grabbings your nuts and then come back to the truck, hop in and turn the key off, then put it in park..
Thats good! I plan to print that off!
Old 08-13-2008, 06:55 PM
VroomVroom's Avatar
GMT800 TPMS p/n = 15114379
GMT900 TPMS p/n = 25799331
I'm not sure if it's the frequency (GMT900 = 315MHZ) or something else, but I understand (as well as mentioned above) that the two systems are incompatible.
I rotate every 5k, and take the opportunity to clean up the insides of the tires and wheels. At the same time I add ~ 7-8 psi (about 8 seconds with my compressor) to the tires. After remounting in the new locations, I kick off the process (it is different between '07 and '08, otherwise I'd share...basically, RTFM ) and remove air to earn my two honks at each corner. I then go around again once or twice to get the pressure just right...then, and only then...do I grab my nuts.
Old 08-13-2008, 10:22 PM
JB1
JB1's Avatar
did you do it buy adding air...honk honk...or removing air...honk honk
First take all the valve caps off...set parking brake...turn key to first click...press lock and unlock at the same time till horn honks...let out air of valve on DS FRT till horn honks (maybe 10sec)...after honk go to PS FRT and let air out till it honks...then go to PS REAR and let air out till horn honks...then go to DS REAR and let air out till horn honks twice...honk honk...system relearned
Next turn key to off and unlock parking brake...DONE
Now go check your air and adjust as needed
It literally took me longer to type this than it did to do the relearn.
You can do it thru the DIC, but your gonna have to read the manual for that
Old 08-14-2008, 06:27 AM
circusboy's Avatar
^^^ I didn't set the parking brake. Maybe thats why mine didn't work.
Old 08-14-2008, 06:59 AM
JB1
JB1's Avatar
could very well be...fuggin comp sees everything so who knows.
Old 08-14-2008, 10:41 AM
VroomVroom's Avatar
I've yet to set my parking brake for this. Could be an '08 thing, I suppose.
Old 08-22-2008, 09:30 AM
chevyspeed3's Avatar
Why don't you just take the sensors out your current wheels? Just pay to have the them re-mounted and balanced. Should be cheaper than paying for new sensors
Old 03-05-2010, 12:39 PM
Fastcount03's Avatar
Other than breaking down the wheels and tires, how can you tell if you have tpms???
Old 03-06-2010, 08:21 PM
Mrgoodwrench3's Avatar
this was "dirst track race 81" reply in my thread, lol
anyways the vehicles that have those are junk..i replaced 4-8 of those a day for the dealership here in town.
It's in the manual in your glove box.
That is really funny! Sometime I wonder what the hell the engineers are thinking. I have been with GM for almost 15 years in the dealership and have to do these procedures all the time. There is another just as ridiculous to program key fobs.
Old 03-06-2010, 10:03 PM
Where's the Beef?
viciousknid's Avatar
I'd just pay attention to your tires and check them when they look low'
I have a set of 315mhz sensors that are new. 1648539179, 25920615 are the numbers on them.
sell them cheap.
Quick Reply: Tire Pressure Monitor
