Tire Pressure Monitor
#22
Put the 06' sensors in the 08 wheels. They are different, 06 is a 2 piece and you unscrew it from the outside using a 12mm socket, 08 looks like a normal valve stem but is also a 2 piece, remove the sensor from the stem by removing the t-10 torx screw then remove the stem reverse to install. Both require the tire to be off the rim or in a position you can access the inside of the wheel. Go to your local dealer ask for the goodwrench and go 39.99 oil change with tire rotation special that is going on right now and the relearn is part of the rotate and you get a oil change if you need it. Or do the relearn as stated previous.
#23
that is a great avatar, bob the builders being honest for once
IM getting the service tire monitor light on my 04 yukon, prob had a tire shop **** a sensor up then they put new tires on the wheel...dealership will prob charge me 100-200 parts and labor...i hope its just one thats fucked up. I was pissed when the relearn didnt work
05GMC4.8
08-07-2015 09:55 PM
GMCtrk
07-17-2015 06:39 PM
