Torque Specs
Anyone know the torque specs on the front suspension components?
Ball joints (upper and lower)
Hub bearing to spindle
Tie rod ends
Strut mount to frame
Strut to control arm??
Thanks in advance.
Tie rod ends
Thanks in advance.
i use a ingersoll rand 3/8" 55ftlbs and its never missed a lick. ive dropped my truck with hand tools and as tight as i can get them by hand. but now the air tools are just plain awsome so its however tight you can get it
Finally got someone at the Stealership that was knowledgeable to answer the phone..
Torque specs are as follows..
Upper Balljoint - 37ft/lbs
Lower Balljoint (w/captured washer) 92 ft/lbs
Tie Rod Nuts - 44 ft/lbs
Here is the shocker....
Spindle to hub bearing - 144 ft/lbs
I had him check that spec twice and he says it is clear in the description "spindle to hub bearing". I assumed when he said that that it was the CV nut but no he swears it is for the hub bolts..
DAMN
DAMN
![turd](https://www.performancetrucks.net/forums/images/smilies2/turd.gif)
I work in a technical developement center for Cummins and see failures of external parts on a daily basis.. Most of which are due to techs not following torque procedures or torque specs. I see internal failures where it is something as simple as the wrong lube applied to threads during assembly that causes a high speed come apart.
I like to know that my torque wrench (which itself is calibrated every three months) says something is tight. Not that i think it is..
Nothing against you personally iamkeniff, just two different views on the situation.
Thanks for the input.
Also very nice truck.
Fastener Tightening Specifications
Application
Specification
Metric
English
Axle Shaft Nut
240 N·m
177 lb ft
Brake Hose Bracket Bolt
9 N·m
80 lb in
Brake Hose Clip Bolts
12 N·m
106 lb in
Hub and Bearing Assembly to Steering Knuckle Bolts
180 N·m
133 lb ft
Jounce Bumper Stud Nut
30 N·m
22 lb ft
Lower Ball Joint Stud Nut
100 N·m
74 lb ft
Lower Ball Joint to Lower Control Arm Nuts
70 N·m
52 lb ft
Lower Control Arm to Frame Nuts
175 N·m
129 lb ft
Oil Pan Skid Plate Bolts
20 N·m
15 lb ft
Shock Absorber Tennon Nut
20 N·m
15 lb ft
Shock Absorber to Lower Control Arm Bolts
25 N·m
18 lb ft
Shock Absorber to Lower Control Arm Nut
80 N·m
59 lb ft
Stabilizer Shaft Insulator Clamp Bolts
50 N·m
37 lb ft
Stabilizer Shaft Link Nuts
10 N·m
89 lb in
Torsion Bar Crossmember Bolts
95 N·m
70 lb ft
Torsion Bar Support Mounting Nuts
95 N·m
70 lb ft
Upper Ball Joint Stud Nut
50 N·m
37 lb ft
Upper Control Arm to Frame Nuts
190 N·m
140 lb ft
Wheel Speed Sensor Mounting Bolt
18 N·m
13 lb ft
Application
Specification
Metric
English
Axle Shaft Nut
240 N·m
177 lb ft
9 N·m
80 lb in
12 N·m
106 lb in
180 N·m
133 lb ft
30 N·m
22 lb ft
100 N·m
74 lb ft
70 N·m
52 lb ft
175 N·m
129 lb ft
20 N·m
15 lb ft
20 N·m
15 lb ft
25 N·m
18 lb ft
80 N·m
59 lb ft
50 N·m
37 lb ft
10 N·m
89 lb in
95 N·m
70 lb ft
95 N·m
70 lb ft
50 N·m
37 lb ft
190 N·m
140 lb ft
18 N·m
13 lb ft
im a diesel mechanic also i do when it comes down to bigger machinary but when I can break it loose with a 3/8" ratchet or a 1/2" ratchet without a breaker bar im not going to get out the torque wrench. do what you want im just saying what i do am ive been doing it for 8yrs, never had a problem with any truck ive done
I have a gasser because they are cheaper..
I did the same thing before i worked here. I just like to have a spec in front of me, part of the engineer in me..
I have worked on cars for years, always went with my gut and never had one problem..
I do have one major issue now though I have a set of Moroso Weld on Spring perches, reinstalled the stock shackles, flipped the axle on top of the springs, and now the driveshaft is TOO SHORT!! is this common?
Safe to have the stock shaft shortened and high speed balanced??
![Ripped](https://www.performancetrucks.net/forums/images/smilies3/ripped.gif)
