Torque Specs
Old 11-16-2010, 06:38 PM
Formerly darynC-10/23/10
Daryn's Avatar
the spring perches actually center the axle over the alignment pin. mine did the same thing. it moved it about 1/2" forward or so
Old 11-16-2010, 07:05 PM
ig109's Avatar
Did you leave it that way? Did you have the shaft shortened? I think i saw that you did something different with your shock mounts??
Any suggestions? Truck will not see much track time if any. Towing about 5 days a year..
Old 11-16-2010, 10:25 PM
Daryn's Avatar
you can use a hole transfer punch and drill the holes 1/2-5/8 forward. that will set your axle back to almost stock location . i didnt no anything with mine. i wanted it right in the middle.
Daryn's Avatar
and yes i relocated my springs behind my rear end and vertical
Old 11-17-2010, 10:57 AM
ig109's Avatar
Hows it ride?? I know you have adjustables but in general and with a stockish shock how would it ride.
Thanks
Old 11-18-2010, 01:09 AM
Daryn's Avatar
it rides alot better. the shocks arent at any crazy angles anymore so it dampens the bumps alot better
Old 11-18-2010, 08:17 AM
ig109's Avatar
Great.. I got it all welded up last night.. let it down and found that the wheel gap is about 3 inches at the front and 5 inches at the rear. I will end up drilling the center pin hole forward an inch to recenter the wheel. I had hoped that it wouldnt be that noticeable but it is... and with me doing this that will alleviate the driveshaft being too short as well..
looks like i just need to make some templates and get me some shock mounts cut out so i can mount them in a similar manner to yours Daryn..
Thanks for all the help.. I may end up fabing up my helper bag setup as well.. Im going to make a crossmember that will fit the bags directly over the axle inside the frame rails so it is hidden, i am also going to include provisions to allow the stock bump stops to be installed so that god forbid i ever did blow a helper with a load on at least the bump stops would catch it prior to the wheels hitting the fenders or the axle laying on the frame..
madmann26
04-29-2020 09:17 AM
Jake75
10-02-2015 02:28 PM
Wolftrk99
10-02-2015 08:17 AM
Cammed4ever
09-30-2015 03:38 PM
jscherbs
09-30-2015 07:54 AM
Quick Reply: Torque Specs
