traction ,stabilitrak,ABS after rear shoock replaced
Dears,yesterday i replaced the rear autoride shocks with a similar one after the change abs traction and stabilitrak appears everything were correct the sensor and the copressor fitting were pluged what was wrong?
Document ID: 1871923
Installation Procedure
Install the shock absorber (5).
Install the upper shock absorber nut (1) and the bolt (2).
Notice: Refer to Fastener Notice in the Preface section.
Install the lower shock absorber nut (6) and bolt (7).
Tighten
Tighten the upper and lower shock absorber nuts (1) and (5) to 115 N·m (85 lb ft).
Reconnect the electronic suspension control connector, if equipped (3).
Reconnect the air line (4), if equipped.
Remove the support from the rear axle.
Lower the vehicle.
If the vehicle is equipped with air leveling, perform the following:
• Turn the ignition ON, with the engine OFF.
• Install a scan tool.
• With the scan tool, operate the air compressor for 30 seconds or until rear of the vehicle begins to rise.
• Remove the scan tool.
• Cycle the ignition OFF, then back ON, with the engine ON to allow the air suspension system to regain the desired rear suspension position.
Tighten
Lower the vehicle.
hey bro.. long time! i would check the autoride sensor, are u getting a "service suspension system" warning.. , i would also check for a blown fuse, ive seen it happen a few times
Ok today i went under the car and i found unpluged wire at the rear between the spare tire and the catback but i did not found the place that this wire should be plug in .
thewrx
08-12-2015 08:28 PM
