Tranny Swap Question
Old 05-04-2009 | 12:16 AM
RickLowpez's Avatar
i got a 6spd tranny at cal speed
Old 05-04-2009 | 12:15 PM
Denali Dude's Avatar
I have installed the 4L80e in my 08 silverado and still haven't found an RPM signal. For the transmission to shift at the rpm I want it to.
Now I use the speed to shift in cruising but TCI TCU requires an rpm signal to **** at WOT.
Old 05-05-2009 | 07:56 AM
RIPBOYD's Avatar
Rick you said you had a 6-speed installed you had Jim do that for you? Does everything work good as far as the wiring goes because if so that'd be even easier since Jims the tuner for my truck anyway.
Old 05-05-2009 | 08:18 AM
GMCtrk's Avatar
did your truck originally come with a 4l60e or 6l80e?
Old 05-05-2009 | 02:05 PM
D_reks{5.3}'s Avatar
I think maybe he means he has 1 for sale at the shop. could be wrong tho...
Unfortunately, his beast came with a 60e...
Old 05-05-2009 | 02:59 PM
Bo185's Avatar
A 6l80 shouldn't be a hard swap into a GMT900. Just need the shifter stalk for the tap shift and add the wires and flash the PCM. Just compare a wiring diagram for a 4l60/70 truck to a 09 1500 6l80 truck. Add the wires and connections for the trans. You might have to swap dashes maybe. Seems easy enough. You'll need driveshaft mod. and crossmember as well.
Old 05-05-2009 | 03:26 PM
Came in 60e and I hated that tranny my friend 09 sierra 60e broke today and it has 8000kms on the clock
Old 05-05-2009 | 04:49 PM
RIPBOYD's Avatar
sure enough i called jim today and theres a few things to do the swap but hes done them before and told me if i get him the 6l80e then for the parts he needs to get for the swap plus install and tune 1500 bucks.
Old 05-06-2009 | 12:24 AM
Parke10's Avatar
makes me wanna get a new truck, a new RCSB with a 6.2 and 6l80e would be sweet ****
Old 05-06-2009 | 08:03 AM
RIPBOYD's Avatar
I know where someone can pickup a 6.2L if they're looking...just throwing that out there Parker...you never know
Quick Reply: Tranny Swap Question
