Which trans for 500rwhp?
#32
i am just gona throw it out there, while the 60e built vs. 80e shift kit debate is going on...why dont you look into prices for a 6l80e and be one of the only people that does that. they mate up on the nnbs with different motor options now, get the tcm, crossmember and work with the trans shop to get it all working right. dont forget to get with your tuner as well to get everything to mesh right. dont yell at my noobness but thats what i would do.
#33
oh and i would love to see a 5.3 built with something in this nature of head/cam combo beast mode IMO:
http://www.texas-speed.com/shop/item.asp?itemid=84
http://texas-speed.com/shop/item.asp?itemid=169
#34
08 L76 with the 4L70E tranny, Built it with 13,000 miles on the truck before the TVS1900. Truck is Around 475RWHP tranny lasted 6mo and welded the HD Sprag, build 2 lasted one year and
sprag again. every mod that can be done has and TQ management is being used.
to the point build the 4L80e
![Bomb](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_bomb.gif)
Race in D instead of OD, in D it applies the overrun clutches and helps support the sprag in 1st and second gear, it will release in 3rd making for a slower 2-3 shift.
Or you can get a aftermarket vlave to replave something in the valve body that applies the overrun at all times in the D position, I'm going to do this next time I have the 60e out, but for now I have been just running in D when I race.
It would be nice if someone made a slightly wider sprag assembly for this transmission, I think it would fix alot of problems.
I've made about 25-30 mid 10sec passes at the track on this 60e in my camaro, and countless passes on the street for a full year and a half before the sprag let loose
#35
#36
add a fast intake manifold with the 102mm TB, some internal upgrades and polishing TLC to button it all up nice like, good to go rip the strip up. god i wish i had the money....some day. thanks for the compliment though, im really new at deciphering cam specs and what would work, but with enough research id say anything is possible if done right.
#37
#38
Laid Back
![Nod](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_nod.gif)
#39
well ill just say this much...
i plan on swapping in a 4l80e when the 60e goes out on my NNBS..
mines a CC 4wd with 33" tires so i dont think any 60e is going to hold up when i put some power into it.....
#40
I'm a big fan of the 60e, but in a heavy truck 5,000+lbs, and near 500hp at the wheel, you will have problems with it.
If you did end up running the 60e also run a deep gear such as a 4.56, it really helps out the 60e
What kind of build up are you doing to get 500hp?
This is going in a 07 nnbs so how much do you think it would cost to do a 4L80 compared to a 4L60. As of right now, Morris Transmissions is suppose to do the build.
