Which trans for 500rwhp?
Old 09-02-2010, 09:19 PM
  #41
quicksilverado's Avatar
Originally Posted by KA41
A built 6.0 with a maggie. 3.73 gears, 3200 stall.
This is going in a 07 nnbs so how much do you think it would cost to do a 4L80 compared to a 4L60. As of right now, Morris Transmissions is suppose to do the build.
No need to build an 80e for that combo. A stock 80e in good shape will hold up just fine. I had a completely stock 80e holding 600 rwhp for a little over 80k miles and about 50 track passes at about 700 rwhp. Get a shift kit in it a you are set.
Old 09-02-2010, 09:31 PM
  #42
KA41's Avatar
Any particular year model 80e to look for to go in a nnbs?
Old 09-02-2010, 09:39 PM
  #43
fredkj3's Avatar
one behind a LS motor... look for the cooler lines...
the one you need has the color lines side by side and not one on top of another
the newer the better.. even though supposedly the older ones were stronger... i found one out of like an 02 with 80K and i paid like 700
Rear ¼" Pipe Return/in
Front ¼" Pipe Cooler feed/out
Old 09-02-2010, 09:51 PM
  #44
KA41's Avatar
So best guesstimate to do the swap. $1500-$2000? For everything.
Old 09-02-2010, 10:24 PM
  #45
GMCtrk's Avatar
Yeah, about $2000 for everything including a $900 Yank converter. You end up with twice the transmission any "built" 60e could ever hope to be. Gotta love the 60e and the "rubber band" shifts.
Old 10-03-2010, 05:27 PM
  #46
06murder's Avatar
im wanting to do the 80 swap as well but i have no welding ex...at all so its bout 200 for an stock 80e n kit conver......i wantin to put it in my 06 silverado rcsb
  #47
06murder's Avatar
2000:p
Old 10-03-2010, 05:59 PM
  #48
Gordon0652's Avatar
"Which trans for 500rwhp"
You need to figure in these factors:
-Horsepower
-Torque
-Weight
-Converter
-Gears
-Wheel/Tires
It's usually not horsepower that breaks stuff, it's the torque.
A tooth pick can handle 500hp, but whats on the end of that tooth pick - thats the factor...
Also, what kind of horsepower/torque are we talking about? N/A, Nitrous, S/C, T/C? They are all different, they all hit and come on differently.
EDIT: of course temp. also.
Old 10-04-2010, 01:06 PM
  #49
pasadenaman's Avatar
I spent 3k on a locally built 60e with 5 pinion planet and t/c and it busted over the weekend hauling a boat. So I vote on 80e which is whats going in my new to me truck as soon as the waranty dies + steel shaft and tru tac.
Old 10-04-2010, 07:07 PM
  #50
foxnutz's Avatar
I'd say go with the 4l80e. I did the swap in August on my 08 RCSB. Found a used 80e with 8000 miles on it out of an 07 van. I used the stock converter and it stalls about 2300. Also I installed a Transgo HD2 reprograming kit (I like firm shifts).
08+ 3/4 and 1 ton vans have the 4l80e (and 4l85e) and the T42 trans controller. I used a stock tune from an EXPRESS VAN. There is a write up that gives you all you need to do with a GMT900. The stock van tune needed tweeking. It worked but shifted a little early from 1-2 and 3-4.
My stock 4l60e lasted about 8,000 miles after the supercharger install. I am likely 400 HP or less at the wheels (no cam or headers yet). I race every weekend and tow.
Quick Reply: Which trans for 500rwhp?
