which trans do i have?
How can i tell which trans i have in my 08 CC GMC. On my dash it reads PRND321. Does it say anywheres on the truck? Or would i have to go to the dealer to find out. Thanks guys
Thanks for the fast reply
So if i have the 6L60e how much horsepower could i put into my 5.3L before i run into trouble with the trans?
Alot more than with a 60E. The 6L80E is strong like the 4L80E I don't know if there is a cut off level but some people have alot of power going threw them! Ultimately depends upon your tuner and how much you abuse it.
4L60E start giving people issues with just full bolt on's, you can help this out by geting a better servo as well as geting the transmissions shift firmness adjusted.
The 6L60E is a whole nother deal, pretty strong transmission, not 4L80E strong, but pretty close, I know skipperdaddy is pushing 520+ RWHP and he hasn't had any problems (Although im sure he doesn't beat the **** out of it wherever he goes).
Well im about 90% sure you have a 4L60E in your truck, if your unsure just count the gears when it shifts lol.
Gotcha!
GWEE just FYI
not sure if you know this or not so i'll throw it out there just in case.
i'll use the 4L60E and 6L80E as examples
4 - Denote # of forward gears
L - Longitudinally mounted
60 - Denotes strength, higher number the better, measured in Newton Meter(Metric) IIRC
E - Electronic
6 - Denote # of forward gears
80 - Denotes strength, higher number the better, measured in Newton Meter(Metric) IIRC
E - Electronic
GWEE just FYI
E - Electronic
E - Electronic
