Which trans pan are you guys running?
Thats a good point.... i remember the y pipe being pretty tight against the trans crossmember and the back of the pan. Guess i will have to crawl under there and give it a look. Might have to spend the 200 bux somewhere else.
tru cool 40k cooler with my rims in busy san diego stop and go i never see temps past 170 . if thats what you are looking for. but i mysself had the smae issue with the deep pans and ORY so i said the hell with it
x2... bigger cooler and change the fluid & filter as recommended and your transmission should last a long time unless you get wild with your setup.
lxcoupe
07-21-2015 02:12 AM
