Truck has begun squalling when started in the AM
Old 02-10-2011 | 01:17 PM
iamkeniff's Avatar
it wont work for long
Old 02-10-2011 | 06:58 PM
ig109's Avatar
Truck was purchased new by me... it is coolant, took a sample into our chem lab at work. Looks like a water pump. Is that common on these trucks? Truck has 66000 miles, never been touched mechanically
Old 02-10-2011 | 07:44 PM
iamkeniff's Avatar
never serviced it? you're doing good. mines been in the shop twice for oil leaks. now its outta warrenty bc of the 6.2/6spd swap
Old 02-11-2011 | 07:23 AM
ig109's Avatar
Nope, mine went in about a day after i got it for a fender to be repainted (rail car damage, strap came loose and rubbed thru paint) and it also had a very small transmission leak, pan bolts were loose.
I recently thought i had a rear main leak, but after puting dye in the oil and running it it turned out to be a bad oil filter, it had started to seperate at the crimp near the base.. (carquest filter)
Other than that it runs great and asside from a squeaky belt and a squeaky door hinge the truck hasnt been touched..
Old 02-11-2011 | 10:06 AM
smokeshow's Avatar
Mod with training wheels
Any way you can get a video of this sound?
Old 02-12-2011 | 09:01 AM
ig109's Avatar
Past two mornings it hasn't been doing it..
Apparently it knows i am going to tear into it if it doesn't start behaving..
I figure if i have to tear the water pump off, might as well do a cam swap..
Old 02-12-2011 | 09:44 AM
Robert91RS's Avatar
These water pumps are usually more reliable than 60k but every now and then you get a turd seal or something. May still be covered under the powertrain waranty on an 07 though so if you can confirm a bad pump I'd give your dealer a shout.
wrb002
08-31-2015 01:00 PM
cams 98 silverado
07-31-2015 08:36 AM
Ketis
07-23-2015 01:37 PM
Mossyoakglock
07-17-2015 09:30 AM
black6spdz
07-16-2015 02:32 AM
Quick Reply: Truck has begun squalling when started in the AM
