Truck pulsing after spark plug and wires changed
Old 01-11-2013, 03:58 PM
Z71crawford's Avatar
Default Truck pulsing after spark plug and wires changed
Like the title say after i changed the spark plug and wires in my 08 i drove it and at idle if it sits long enough it will start pulsing every few seconds. The truck shakes a little and the RPMs drop a bit then go back to normal. I used Ac delco iridium spark plugs, with MSD 8.5mm wires for a 99-07 truck. Could the wires be the problem although i wouldn't think it would be? I know all spark plugs were locked down just right. What do yall think could be up? Is the computer learning the new thicker wires? Idk but in advance thanks!
Old 01-11-2013, 04:34 PM
nonnieselman's Avatar
i had a bunch of problems with MSD wires.. i got the cheapest ones the parts house had and no more problems..
i even got MSD to replace 4 of them and still no worky..
put your stock ones back on and see what happens.
Old 01-11-2013, 04:40 PM
shorty's garage's Avatar
I think anything from msd is junk. I make my own wires.
Old 01-11-2013, 05:26 PM
AUTOT3K's Avatar
Did you use diaelectric grease?
That's an insulator not a good conductor
Old 01-11-2013, 06:57 PM
Yeah I think I may send these back! No I didn't use the grease. Probay go back to go old ac Delco
Old 01-11-2013, 07:23 PM
Chevy_King1500's Avatar
8.5mm msd wire worked great on my truck. you need to make sure they are 100% on the plug end.. they can be a little tricky
i would put the stock ones back on. if the problem still persist you may have cracked a plug..
I have a gauge for that
Atomic's Avatar
Crack the porclein on a plug?
Old 01-11-2013, 07:54 PM
iamkeniff's Avatar
Shi i run TR-55 (5.3) an TR-6 (6.2) bosch wires. Cheap plug and wire change with no issues
Old 01-12-2013, 08:47 AM
Trucks getting the 4.56s installed right is so ill do investagation when it get back.
Old 01-12-2013, 09:30 AM
13 Second Truck Club
LS1FREEK's Avatar
Ive had 3 sets of MSDs and never had a problem. If I had to guess, you may have cracked a plug.
Quick Reply: Truck pulsing after spark plug and wires changed
