VVT Cammed 6.2L
#41
Who did your tuning? Familar with Doug Rippie performance in Waverly MN?
I am thinking about a dyno tune on this after the stall, is there much to be gained or would sticking with Justin from BBP be fine via the autocal. What do you guys think? What would you do? Prices is looking like $400-$650 and the higher end is a dyno tune, the lower price range being for a wideband street tune (with HPT i believe) which seems not much better than the autocal route.
#42
Yeah I did the install myself. Takes a couple days, not too bad working on something that's newer.
#45
Some may hate this since my truck does not have the GMPP crate lsx 376 in it, but here are my new emblems. They are going on the doors where the stock emblems are currently. Soon as I get a day in the 60's I'll get the old ones off, buff it and get the new ones on. They are flat black in color to match the flat black Z71 decals on the rear quarter. Feel free to hate and call em or like em or whatever. If you want the manufacture info on these PM me.
#46
Couple quick Revs and a bit of idle with cutout open - 15 sec
Got the tuning closer with Justin, it still starts hard and it has died when I put it into reverse a couple times before engine is all the way up to temp so it is still a work in process. Had a misfire which was the result of a bad plug, but got that solved. So get the engine tuning dialed in and the trans tune as well for the new converter and then it should be done... for now...
#47
Finally some videos, all are kinda shakey but u get the point.
6.2L cold Start Open Cutout
From a Dig
Rolling Pull
Bit of Driving with the new stall and a dig at the end
Freeway Pull
From a Dig
Rolling Pull
Freeway Pull
#49
Sounds mean!
I'm curious if using a dyno you could dial in the tune with the VVT any better or can it be pretty much done on the street? I figure with a dyno you can see the changes when advance/retard the cam when on a dyno... kinda thinking out loud here
#50
i did that with mine. picked up some power as well.
