vvt deleters, enter here
Sorry to ressurect an old thread, but I've just started researching the VVT delete for my L9H and I was just curious if this is all that is needed for the 6.2? I definitely want to swap to the 3 bolt sprocket so I'm assuming this is the most accurate parts list? I'm going with the TSP LS3 blower cam and will be strapping a TVS2300 to it after, I'm assuming this parts list will suffice?
Just rolled over 12000miles...I'm assuming that isn't much considering I've had it over 2 years...should the crank seal still be changed? Would it last longer if I just changed it anyway? The cost is justifiable if it will hold up longer than the original...
You should be fine. Mine had 40,000 at the cam swap and still looked good.
