what 1/4 time yall hit with only boltons????
Old 02-06-2011, 12:44 PM
  #41
summithighrise09's Avatar
SUBSCRIBED....keep this thread going fellars, I will post my times once i go see the wizard(Wheatley) and after getting all my BOLT ON's/Simple Mods put on when i return from my deployment.
Cam
Old 02-06-2011, 02:44 PM
  #42
gs7793's Avatar
Originally Posted by 08Chevy
LOL at watch my language like we are little children.
Ok, then tune isn't used as a bolt on. Either way, you can still use the term bolt on for other things.
MY opinion of a bolt on is something that can be added to the truck that doens't need major adjustment for. I can add a cold air intake and truck still run normal. I can put long tubes and the truck still run fine other than the o2 sensors. Bet you can't put a cam in a truck, WITHOUT a tune and other crap and it run as good as stock. So its not considered a bolt on. I don't consider nitrious a bolt on cause you still have to tap into your intake and run wires and stuff.
The term bolt on is just used for easier things that can put on a truck to add performance/help the truck gain mpg or what ever you need it to do.
trucks run worse with LT's untuned...sure you can drive em around fine but there's no point in having em if your not gonna get a tune....
Old 02-06-2011, 03:15 PM
  #43
SincalT/A's Avatar
LMAO! @ THREAD....
Bolton makes terrible music btw.
Jus a suggestion you might be able to weed out the jokers if you ask in a diffrent manner such as "Looking for track times with stock longblock w/ no fi.?"
Old 02-06-2011, 11:18 PM
  #44
GMCSIERRA5.3's Avatar
^^and why would i put stock longblock or something?? if u have a built block obviosly your gonna have cam heads etc... im asking only boltons!!!!!!!!!! is FI a bolton? to some people it is but too most of the people its not a bolton..
Old 02-07-2011, 12:08 AM
  #45
SincalT/A's Avatar
Because,stock long block suggests that no internal has been done.No If ands or buts about it.Hey,put whatever you want it was jus a suggestion.
Old 02-07-2011, 12:45 AM
  #46
Most Hated's Avatar
13.0@103mph 6.0 rcsb fbo
Old 02-07-2011, 06:01 AM
  #47
skipperdaddy's Avatar
15.0@93 obx lts & ory, cai, Truckshop tune, magnaflow 14", stock 20s, 3:42s, and a diamond plate toolbox full of junk! Lol! 09 CC 5.3
Old 02-09-2011, 10:54 PM
  #48
Jordan927's Avatar
My definition would be anything that can be done using basic hand tools and without taking apart any of the drivetrain. (engine, trans, diff)
I would have to agree that giggle gas, tune, CAI, exhaust (all of it), e-fans, lighter wheels, stickey rubber that sort of thing. Basically modifications to the drive trains supporting systems. You don't need any of these systems to run the drive train.
Cams, intake manifolds, pistons, rods etc, Internal engine mods.
Vette servos, clutches converter, etc, Trans mods.
Larger gears, stronger shafts, etc, diff mods.
And S/Cer or turbo is FI
Old 02-10-2011, 09:27 AM
  #49
08Chevy's Avatar
:facepalm: Seeing that a 6.0 never came into a single cab, I wouldn't consider your legit for this thread.
Old 02-26-2011, 04:38 PM
  #50
well finally went to the track hit a 14.9 fml lol i think i shoulve have gotten better times but idk lol
Quick Reply: what 1/4 time yall hit with only boltons????
