Whats causing this? .. W/video
Old 09-16-2014, 04:12 PM
  #21
03SuperSLADE's Avatar
Originally Posted by wanablaze
Rear speed sensor (VSS) is not in trans tailshaft on 4wd models; it's in the rear of the transfer case (top side). Good luck, hope you get this sorted out!
I was wondering, does anyone know what would happen if you used the rear VSS on the 4l80e instead of the one transfer case?
Old 09-17-2014, 05:52 AM
  #22
BIGDADDY1969's Avatar
Question
Im 2wd and theres no sensor anywhere ... Only wire on the 6l80e that i have is the TCM plug ...Thats the odd thing i guess this trans doesnt have it lol
Old 09-17-2014, 10:54 PM
  #23
wanablaze's Avatar
Just a thought; do 2wd models use the rear wheel speed/rear abs to determine vehicle speed? Can you confirm that the TCM & PCM were flashed with correct gear ratio?
Old 09-18-2014, 01:52 AM
  #24
Registered User
Requeson's Avatar
I had the same problem n I checked my tranny fluid n it was supper low after I added oil it went to normal
Old 09-18-2014, 03:26 AM
  #25
Cool
I didnt have this issue im having in the video until recently.. Ive had the 6l80e swap done and ECM swap and flashed over a year ago and didnt have this particular issue until now .. And i was thinking the same thing about rear abs but i dont see wires coming out of rear brakes .. Only wires on my brakes are the fromt ones .. Wondering how to tell if they are bad or whoch one since im not getting any codes saying bad sensors?
Old 09-18-2014, 03:28 AM
  #26
Cool
Will check mine today but i always check my fluids regularly and it was good last i checked.. Wont hurt to check again though .. The more i think about it the more im figuring its the torque converter but thats hust my feeling im having ... Especially with the stutterin through the drivetrain to the rear like it does when the rpms goe up n down
Old 09-19-2014, 08:21 PM
  #27
wanablaze's Avatar
If you think it's torque converter I'd have a shop or someone with proper scan tool test drive and monitor torque converter slip % and command. Lot's of live data for this trans. Good luck! Swapped a 6L80E into my truck also and today it missed a 2-3 shift and hit the rev limiter on factory tune?!? Hope this wasn't a mistake because it drives so much better overall.
SloSVO
11-22-2020 07:34 PM
TAPyvehc93
01-08-2016 10:47 AM
bearden86
26
11-15-2015 03:58 PM
Velocity1
10-02-2015 08:01 AM
Slammed silverado
09-28-2015 06:14 PM
Quick Reply: Whats causing this? .. W/video
