who HAS done a cam swap on a nnbs
Old 07-30-2008, 08:42 PM
  #51
Y2KLimited's Avatar
FWIW my 07 6.0 2500 sub has VVT....presented a few problems when we first tuned it for the blower, since the shop is 95% vettes, and well vettes don't have it.
Old 07-30-2008, 09:40 PM
  #52
MNC5's Avatar
Ok, but you still have the stock cam right? What problems did you have with VVT and the blower?
Old 07-30-2008, 09:58 PM
  #53
Y2KLimited's Avatar
yup stock internals.
We had problems with tuning it with the blower because we didn't realize there was a whole other page of tables associated with the VVT stuff (and also a new version of EFI live at the same time to complicate things further) once the guys figured out that VVT table things fell right into place, but before that they had so much timing out of the truck and it was still pinging with the boost backed off, 93, octane booster, you name it...but the VVT stuff was entirely on its own and independant of the normal tables...
(what i was told I don't touch laptops and software ever since wiping out a motor 5 years ago trying to learn DFI)
Old 07-31-2008, 07:31 PM
  #54
scooter k's Avatar
What about the lifters? Has anyone replaced DOD lifters? The stock lifters on the DOD cylinders have a notch on the lifter so those lifters will only fit in DOD cylinder lifter bores. Does this matter when replacing them with conventional lifters?
Old 07-31-2008, 08:03 PM
  #55
circusboy's Avatar
I did not replace stock lifters on DOD motor. I've had 2 difference cams in and didn't change them for either.
Old 07-31-2008, 09:14 PM
  #56
Tootall's Avatar
Originally Posted by scooter k
. . . The stock lifters on the DOD cylinders have a notch on the lifter so those lifters will only fit in DOD cylinder lifter bores. . . .
never heard of that . . .
but why would you want to replace the lifters on a new motor? It's just a cam/spring/push rod swap.
Old 07-31-2008, 10:10 PM
  #57
scooter k's Avatar
I didn't know if the everyone was replacing the lifters or not? Will the dod lifters hold up?
Old 11-24-2008, 10:14 PM
  #58
Noah Burns's Avatar
i have a brand new 215/215 LS1 cam I want to throw in my 08 dod truck... i have a ton of timing sprockets from my 01 truck 01 camaro, etc etc, will those work for the swap? I have a brand new set of 850 lifters I wish I could use too but I don't think they will work.
Old 11-25-2008, 08:46 AM
  #59
nighthawk08's Avatar
Originally Posted by circusboy
My 5.3 motor didn't have VVT. I heard the 08 5.3 does. How is this being accomplished and will it effect a cam swap? just trying to educate myself a little.
there are no 5.3's that have VVT.
Old 01-12-2009, 03:46 PM
  #60
red_silver's Avatar
Ok so I just want to clarify here. 08 5.3's and 6.0's for a cam swap all you need is the LS7 sprocket? Not the 6.0 needs the sprocket and the 5.3 doesn't or vice versa?
Quick Reply: who HAS done a cam swap on a nnbs
