Who makes the BEST lowering kit?
#21
Also, there is an adapter you can run instead of drilling out your spindle. I can get you the info if you need it. But basically you have to drill out the spindle where your TRE goes in. OR, you can run that adapter. Just depends on what you want to do.
#23
Welp, I got the bump steer issue solved! I bought some beltech struts, and during the swap, I noticed that my factory struts had no dampening for about the first inch of travel, allowing my tires to bounce all over the place when hitting bumps. Problem solved!
#24
Ryan, glad you got it fixed.
signguy62
07-27-2015 03:42 PM
