Why Delete AFM ..... stock cam
Tin Foil Hat Wearin' Fool
Oh I dont doubt that they fail, Ive read before that they do, just playing the probability game. With as many people on the performance forums that beat the hell out of their vehicles far beyond the average user there arent any people that Ive read of having the lifters fail on stock cams. You would think if theyre that bad then atleast one case would be documented on the forum. The only way he can truly be sure that he wont have a problem obviously is to delete them and run an LS7 replacement, me personally I wouldnt worry about it.
Where's the Beef?
Not meaning to tread jack but, I just got my AfM turned off when wheatley tuned my truck and its shifting at 6000... Should I be worried??? 48000miles, would be a shame to lose my 50,000 miles of remaining warranty... Your thought's gents? Stock cam 5.3
When they're pumped full of oil, the AFM lifters are essentially doing the same thing and should be as strong as the non-AFM ones (at least in terms of the spring pressures they see in a stock engine). It's really only above .500" valve lift that the AFM lifters are going to be at severe risk for failure but since OP doesn't want to change cams, it's really a non-issue.
BTW the first thing the tech will do after diagnosing a lifter problem on your truck is send your tune parameters to GM to check for an aftermarket tune.
If they look hard enough the answer is a definate yes. What seems to be unclear at this point is how hard they look most times. These new ECMs have a flash counter and odometer that may go unnoticed but its going to be a risk.
That was part of it but it also keeps you from swapping ecms. If you put 20k miles on a ECM with a aftermarket tune but swap it back to the factory ecm before heading to the dealer for warranty repairs it won't match the mileage on the cluster.
