Z71 GUYS! Launching in 4wd? any secrets?
2nd fastest 5.3 ECSB
I use 4hi on the track and on the street for wot launching. I only use 4auto for wet or slick conditions. Do like Thunder said. if you can get it back into 2wd do it as soon as you can without losing traction, for me that is after the 1-2 shift or i am wall bound
![Icon Lol](https://www.performancetrucks.net/forums/images/smilies2/icon_lol.gif)
thanks man, i will give it a try.
i took this advice when i started putting some power down and it has worked out great for me. but i am curious if i would see any faster et's if i could get it to hook in 2wd.seems to pull harder in 2wd...maybe its just in my head.
![Arrow](https://www.performancetrucks.net/forums/images/icons/icon2.gif)
![Shiftin' Fool](https://www.performancetrucks.net/forums/images/smilies/3.gif)
i think you are right it seems that it pulls harder in 2wd.
Of course it pulls harder in 2WD. Think about it for a second. Common belief is that manual trans vehicles lose about 15% of their flywheel horsepower to driveline losses and auto vehicles lose 18%-20% due to the torque converter.4X4 trucks probably fall into the 20% category due to their heavier drivetrains. Let's say your modded engine is putting out 400 flywheel HP. That means you're probably putting out 320 rear wheel HP. Now, if you add in turning a transfer case, front driveshaft, front gears and axles and driving those heavy front wheels and tires, you must be losing another 20% of your potential Wheel HP. Now you only have 280 HP pushing 4 wheels.
Parasitic losses can amount to a fair amount of HP. Look at the difference switching to electric fans can make versus an engine driven fan. Perhaps someone who runs their truck in the 1/4 has tried it in both 2WD and 4WD, same track, same day and can post their results.
![Cheers!!](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_cheers.gif)
Parasitic losses can amount to a fair amount of HP. Look at the difference switching to electric fans can make versus an engine driven fan. Perhaps someone who runs their truck in the 1/4 has tried it in both 2WD and 4WD, same track, same day and can post their results.![Cheers!!](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_cheers.gif)
I disagree. I just went out and laid under my truck and I can spin the front driveshaft with my hand, park brake on, truck in drive. When you are in autotrac, the transfer case is turning, just waiting for the computer to detect tire slippage and engage the front diff. When you are in 2WD the transfer case is not turning, that's why they came up with the autotrac system. The fuel economy would be horrendous if the transfer case, driveshaft and axles were always turning. This does not apply to a Denali with AWD.
![Happy](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_stretch.gif)
