2014 gmc 3/5 drop rcsb
Old 05-19-2015 | 06:07 PM
red07's Avatar
Default 2014 gmc 3/5 drop rcsb
Just got her done. 4x4 gmc rcsb 3/5 drop
Attached Thumbnails 2014 gmc 3/5 drop rcsb-image.jpg
Old 05-19-2015 | 10:17 PM
stereojnky's Avatar
Nice!
Old 05-20-2015 | 01:26 PM
BCraven1018's Avatar
Looks Great!!
Old 06-26-2015 | 03:07 PM
blownZ71's Avatar
What kit did you use? How does it ride compared to stock? Aluminum or steel control arms? No issue with the driveshaft?
Thanks for the help, looking to do the same thing.
Old 06-26-2015 | 05:43 PM
red07's Avatar
Used drop spindles had to switch a arms to steel. mcg spindles strut spacers flip kit in the rear with lift hangers
Rides a little stiffer than stock. And had to add 2 degree pinion shims to smooth out vibration
Old 06-26-2015 | 05:51 PM
red07's Avatar
Drop kit 34125
Had spindles saved for a while
Bought steel used arms
No issues with drive shaft. Kit moves rearend back on the springs a bit
Old 07-02-2015 | 07:27 PM
blownZ71's Avatar
Drop kit 34125
So drop kit 34125, AND you used some drop spindles? Who makes those? Replaced both upper and lower control arms, did that require anything else? How was the install?
Thanks again
Old 07-10-2015 | 05:59 AM
red07's Avatar
Mcg spindles. Install was not to bad. No other parts
Old 07-11-2015 | 11:16 AM
silver-mod-o's Avatar
Hunt&Fisherator
Those Denali wheels look like they belong on that truck. Very nice!
Old 07-11-2015 | 12:50 PM
Randy 5.3's Avatar
Whats the logic behind lowering an Off-road vehicle?.....Looks clean BTW.
