Lifted 14' 6.2 ran a slow 14.1@97, need some help with tuning issues.
Old 01-25-2016, 08:34 AM
RSmith6.2's Avatar
I was happy with the 1.9 60', it rips all 4 tires off the line. Off idle TQ is insane. Just need cool air and it should run 13.90s. That's what I expected anyway. I've seen bone stock trucks like mine run 14.0. So a catback and tune only got me back to what I would run without the lift and tires. Lol.
Old 01-25-2016, 10:39 AM
RSmith6.2's Avatar
Yea I see nothing in this thread to be disappointed about. You ran a good time with tires that are killing you and IAT's that were pulling timing. Take those 2 factors out of it and you're looking at a low 13 second truck.
Thanks. I have a set of 28x14.50 Hoosier slicks from my drag truck, but it's 8 lug. Not sure 16" rims will fit on the disks in the back of this truck, but if it will I'll buy another set of rims to put them on.
Any ideas on why the throttle is limited to 84%? Or how to make it open all the way?
Old 01-25-2016, 11:12 AM
Vortec350ss's Avatar
It is opening all the way. The scanner tool will only read 84% though.
Old 01-26-2016, 10:20 AM
LIL6BT's Avatar
You're logging the wrong PID. The PID you are logging (TPS) only goes to 84%.
Log the actual pedal and the throttle body, that way you can see how the pedal corresponds to the throttle body. They will show different numbers since the TB is computer controlled. You want to make sure that you are getting full opening.
Are you logging with HP or EFI live?
Edit
I just read back and saw HP Tuners. Are you using 2.24 or 2.25 Beta to log?
Last edited by LIL6BT; 01-26-2016 at 10:21 AM. Reason: Re read and found detail I needed
Old 01-31-2016, 12:41 PM
gonzo 6.2's Avatar
Try it with stock catback,mine ran harder tuned stock catback vs tuned MBRP catback running my buddy,doesnt make sense i know
14.1 big *** tires,thats good,and 1.9 real good
Old 01-31-2016, 07:00 PM
RSmith6.2's Avatar
14.1 bid *** tires,thats good,and 1.9 real good
Wow one of the originals, wasn't sure any of the guys from the old days was on here anymore. I hadn't logged on in years because it got so bad on here with the trash talking, my old username was SnakeEater since 2002, but I guess it was deleted for being inactive so long.
With the 4" catback it seems to breath better up top, but what really woke it up was copying the vette cam timing over. No anything under 20mph it'll light the tires up and spin into second gear. I'm still somewhat confused about the 84% throttle thing, but I can solve that with some research. I really need to get cold air in, that's what's killing my times.
Old 01-31-2016, 08:02 PM
gonzo 6.2's Avatar
wow snake eater,yes I know, it has got nasty here I post very little spend not much time here.A lot of hands on guys have drifted way.Glad your back
Hey what gears in your 014?
Old 01-31-2016, 08:18 PM
RSmith6.2's Avatar
3.42s
Old 01-31-2016, 08:27 PM
gonzo 6.2's Avatar
I have a vid of my buddy 014 3.42 vs my 014 3.73 both all stock 6.2s.maybe a truck length advantage
Old 02-01-2016, 07:44 AM
RSmith6.2's Avatar
Single truck length is a lot of time in the 1/4. I don't think I need lower gears though, it already spins all 4 off the line. Just need more top end.
Quick Reply: Lifted 14' 6.2 ran a slow 14.1@97, need some help with tuning issues.
