***PRISTINE 6.0L Parts***
Old 06-09-2008, 08:56 AM
9 Second Truck Club
stock48's Avatar
Default ***PRISTINE 6.0L Parts***
I have some really nice 6.0L parts.
-Special short skirt Lq4 pistons with pieces of rings.
-Custom "S" rods, broken beam style.
-Oil pan, tray, and pickup(ventilated sump style)
-Open chamber head.
-Custom ISKY turbo cam (need to be welded back together)
-STD 6.0L block (needs 3 sleeves, hole in side, and pan rail repaired)
-Set of 11 bent pushrods
-truck style linkless timing chain.
-6.0L crank with two good journals.
Old 06-09-2008, 09:04 AM
How do I change this text
Wilde Racing's Avatar
wow number 7 is o.k????
Old 06-09-2008, 09:16 AM
9 Second Truck Club
stock48's Avatar
Other than being .100'' down in the whole looks ok. None of the ring lands on the pistons still left show any sign of detination. Bearings look like new. The rods just shortend until failure, I suspected something was going on fo some time. I had low compression on a few holes, but no blowby.
Old 06-09-2008, 09:47 AM
BigCountryx's Avatar
Looks like a perfect opportunity for a 2 year build and 2000 post thread.
Seriously, Sorry to hear 'bout that... what's the plan? What were you doing when she let go?
Old 06-09-2008, 10:01 AM
charcold-bowtie's Avatar
so how much and stuff. Ive been wanting to build a 6.0 hehe. Thats nasty
Old 06-09-2008, 10:02 AM
KySilverado's Avatar
Dayum. Some stresses going on there.
Old 06-09-2008, 10:09 AM
ZR1 DREAMING's Avatar
YEEESSSSS!!! That's awesome!
What's going to take it's place?
LMAO!!
Old 06-09-2008, 10:15 AM
High on diesel fumes
thunder550's Avatar
Wow....well if anyone wanted to know what it took to find the limits of a stock internal 6.0L engine, there ya go
Old 06-09-2008, 11:06 AM
2nd fastest 5.3 ECSB
trever1t's Avatar
How much for the "S" rods? Do you have a full set??
Old 06-09-2008, 11:17 AM
hirdlej's Avatar
Did you have your pistons flycut or is that from the valves hitting? Looks like someone didn't check their piston to valve clearance
Quick Reply: ***PRISTINE 6.0L Parts***
