***PRISTINE 6.0L Parts***
Old 06-10-2008, 02:36 AM
  #31
9 Second Truck Club
stock48's Avatar
Originally Posted by southern_chevy
Well at least you dont half *** anything when you break ****. So what are the plans?
6.0L +.030'' , Compstar rods, Mahle pistons, stock crank, same cam, same hand ported factory heads just replacing one, and some really nice machine work. Sonic tested the block and it's .280'' thick on the thrust side.
Attached Thumbnails ***PRISTINE 6.0L Parts***-jf91.jpg   ***PRISTINE 6.0L Parts***-jf111.jpg
Old 06-10-2008, 02:43 AM
  #32
GFYS and STFU
Spoolin's Avatar
You take your break-in periods a little too seriously...I don't think that's what GM had in mind during initial break in. Better luck next time though.
Old 06-10-2008, 02:44 AM
  #33
9 Second Truck Club
stock48's Avatar
Originally Posted by BigCountryx
Looks like a perfect opportunity for a 2 year build and 2000 post thread.
Seriously, Sorry to hear 'bout that... what's the plan? What were you doing when she let go?
It will be running in 2~3 weeks! I need my daily driver back this diesel is too expensive. I was racing down in vegas, 14~15PSI. https://www.performancetrucks.net/fo...d.php?t=418132
Old 06-11-2008, 05:12 PM
  #34
moes04silverado's Avatar
Originally Posted by thunder550
Wow....well if anyone wanted to know what it took to find the limits of a stock internal 6.0L engine, there ya go
my #3 and #4 did the exact same thing - damn i know the pain!!
Old 06-12-2008, 04:54 PM
  #35
Sierra1320's Avatar
I know the LQ4 has a little weaker rods than the LQ9 and, but in the later year engines don't they use the same rods now?
Old 06-12-2008, 05:01 PM
  #36
9 Second Truck Club
stock48's Avatar
Haven't had my hands on a 05 up 6.0l yet, but the LQ9's, and LS2are alittle beefier. The stock LQ4 piston's are stronger than the rods. I have 4 bent rods with good pistons on them.
Old 06-12-2008, 05:11 PM
  #37
Sierra1320's Avatar
What kind of mileage did you get before the 6.0 decided to chat with the engine gods?
Old 06-12-2008, 05:51 PM
  #38
TG02Z71's Avatar
What are the Mahle pistons coated with??
Old 06-12-2008, 06:06 PM
  #39
kbracing96's Avatar
Performance coatings include a phosphate dry lubricant that is used to protect against ring micro-welding and pin galling during initial startup and break in. For added performance, MAHLE applies its proprietary Grafel anti-friction coating to each piston skirt.
I'm going to be running these pistons in my new motor as well
  #40
9 Second Truck Club
stock48's Avatar
Break in time??
Quick Reply: ***PRISTINE 6.0L Parts***
