.045" head gasket choice?
Is there any other company beside Cometics that sells a .045" head gasket (or close to) for a 4" 6.0?
If not, whos got the best price for Cometics?
Originally Posted by tdrumm
I got mine from SDPC. I think they were around $130 for the pair.
I also have heard that Fel-pro makes a .045 but I could not find it when I was looking.
Yeah I haven't seen any fel-pro ones yet either.
I've heard of Titans their called I believe but haven't found a good site that sells them.
Originally Posted by 4.8T
summit has the felpro ones. thats where i got mine.
I did look through summit and found some for a 4" bore but it doesn't say what thickness they are. Guess I'll have to dig a little deeper.
Good find 4.8T.
I wonder if it makes a difference if I go with the 4.135" vs the 4.03" I was thinking about.
I see SDPC has 4.160" Cometic gaskets for only $120.
What pro/cons is there to going with a slightly larger bore gasket? IE: 4.135" vs 4.160"
I was going to run a 3.910 bore gasket with my 3.78 bore, Cometic said I would have no problems with it except a little less compression than a gasket of a smaller bore but same thickness.
gasket
here you go .041 not .045 sorry but they are 4.135"
So now the real question is, since the Fel-Pro's are basically the same price as Cometics. Which would be the better choice?
