1000 HP/Torque. What will it take.
#101
I was out walking the pooch (the actual cannine pooch) this morning and thinking, as I usually am, about the build and a Procharger F1, F1a or something close, on a 390 and it again occurred to me that I ought to do a LQ4 based 427 with the big Procharger or a turbo.
I still like that. It satisfies the big cube guy from the 50's that still makes up part of my psyche and it uses the new technology of turbo's or Procharger blowers. It doesn't do much for the "show" that I love in the Maggies but they apparently don't have the boost numbers necessary to do big hp... but, come to think of it, I haven't yet taken Grippy's suggestion of talking to Left Coast. I'd prefer the show of the Gimmy clone on top if I can reach my goal. Maybe with a 390/408, fairly high compression and a TVS 2300???
I gotta call Left Coast.
I agree just because Kenne Belle isn't discussed much on here doesn't mean it couldn't be perfect for you. The whipple setup isn't highly respected on this board due to poor customer support and the lack of an intercooler. I was able to get almost 500whp with my setup on a stock 6.0
#103
I'm now thinking a LQ9 stretched to 427 and then I'm vacillating between the Kenne Bell and a F series Procharger with a tall intake like the Edelbrock or one of these........ http://www.precision-metalcraft.com/Home_Page.php
(wish I had the $$$ for one of them but you get the idea)
![Grin](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_grin.gif)
#105
GFYS and STFU
#106
Assuming pretty big cubes are what I want, what block would you recommend I figure on starting with?
I appreciate help as much of my experience started about 1958 and ended by the 1964.
#108
Aren't they expensive? Or... would I end up with just as much in a LQ9 after the machine work was done? Come to think of it... The thing that got me going with the LQ9 was a story in GMHTP mag about a C5 that had a 427 built from a LQ9.
#109
GFYS and STFU
Don't get me wrong, it's a viable route for sure, it's probably the cheapest block you can get that can go to that size, most people like those because they are iron. just was curious as to what made you want to use a LQ9 that's all.
Benefits of the blocks Atomic mentioned is those can go much bigger than 427. An LSX Tall Deck can go to 488 ci safely and some have taken them into the 5xx ci range when re-sleeved.
Re-sleeved aluminum blocks have held up 1,xxx hp successfully as well. LS7 block is 427 ci out of the box. Just giving you idea's. You'd have to do a comparo on machining costs and re-sleeving costs to see which one is cheaper, but the block atomic mentioned are around $1500-$2000.
