110 lsa cams
110 lsa cams
Anyone use a cam on a 110 lsa? How do you like it? Hows the powerband? Curious to find more info cause all I can really dig up is info on 112-114 lsa cams...
110 is good on extreme ramp cams, lets say you have a 5.3 with a 224r on 112, go with a kr lobe hi lift 224 with a 110, this will give you every bit of the top end just brings the power band in quicker, this will build more compression at the low rpm witch means more torque.
I remember that. How did the little 4.8 like it?
No ****
Im looking at a cam that comes on early and hits hard.. Did you tune it yourself??
I was looking at the 220 and 224. I really dont want to go any higher on duration than that...
No ****
11 Second Truck Club
I got my base tune from fastchip but I have had to dick with the idle alot till I got it right...
This was just after I dropped in the bench tune. (It would have idled much better if I would have taken it to him again) http://www.youtube.com/watch?v=QyIRI...eature=related It'w much better now.
If your gonna stay in the low 220-224 you'll be fine, Mine is 236/244.
