110 lsa too tight?
110 lsa too tight?
Is a 110 lsa too tight for a 5.3? The reason I ask, I saw a dyno of a 224/224 xxx/xxx on a 110 +4 and the graph dropped of at like ~6200 rpm. Seems like it would be ideal for someone not wanting to turn a lot of rpm and still benefit from the higher duration.
i wouldnt necessarily say its TOO tight depending on your stall and other mods, its gonna shrink your power band down pretty good though. i would compare that dyno with another one of 112 or 114 and check the area under curve. though the power will be greater, you are going to start making it later in the RPM's but your peak torque will also come earlier. a 224 on a 110 IMO will be understalled with your tt2600. in case you havent seen this before....
.Varying Lobe Separation Angle.....................................
...............Tighten............................ ..............Widen
Moves Torque to Lower RPM..............Raise Torque to Higher RPM
Increases Maximum Torque................Reduces Maximum Torque
Narrow Powerband...........................Broadens Power Band
Builds Higher Cylinder Pressure............Reduce Maximum Cylinder Pressure
Increase Chance of Engine Knock........Decrease Chance of Engine Knock
Increase Cranking Compression...........Decrease Cranking Compression
Increase Efective Compression...........Decrease Efective Compression
Idle Vacuum is Reduced....................Idle Vacuum is Increased
Idle Quality Suffers..........................Idle Quality Improves
Open Valve-Overlap Increases...........Open Valve-Overlap Decreases
Closed Valve-Overlap Increases.........Closed Valve-Overlap Decreases
Natural EGR Efect Increases..............Natural EGR Efect is Reduced
Decreases Piston-to-Valve Clerance....Increases Piston-to-Valve Clerance
yup, turbo berzerker sent that to me when i was deciding between 112 and 114 and i have found it helps alot of people to know what they are getting when the widen/tighten LSA
I am not sold on the 224 alone, just the fact that the rpms drop off so rapidly with the 110 after peak. in addition, the chart is tightening and widening from what reference lsa? Stock?
FarmerBeau, I see you are on a custom cam. Are your durations above, at, or below 224? I know you do not want to give it away. Also, what is your converter stall rating?
Vortec350ss
01-12-2016 10:36 PM
