1st LS 408 engine build
What's up guys need a little help trying to make some power the the bolt ons on the 4.8 have gotten old and gotten me beat to many times now ready to step up with the big dogs and go fast. Here is my plan LQ4 408 because I want to stay N/A but I don't know where to go with the heads. Once I get a LQ4 and the rotating assembly I will be low on cash what should I do with stock heads to make about 400 HP heres my plan for the bottom end.
Lunati Forged 4" Crank Lunati 6.125" H-beam with ARP 2000 Rods.
Get comp cams to grind me somthing a little loopy and torquey and all the valvetrain goodies from them. But I have no idea on milling numbers or compression numbers I need help there. I almost forgot pistons I'm looking at Wiseco 4.03'' -3.0cc flat top from TSP
Either way, you wont be running with any "big dogs". But it will be a good running truck.
go with an Eagle crank over the Lunati and save, what, $1000? That would open up room to do more with heads. I've seen 408, big cam, absolute stock LS6 heads make 450+ to the tires by the way. My theory is always to get your budget to the right place before you start the project so you can do it all the right way and get the best results out of it. Is that 65E a stocker?
400-450 hp to the wheels with a 408 under the hood of a DD is a big enough dog for me and where I race.
O well I just had it rebuilt with all the stuff in my signature ( .500 boost valve Raybestos, Kevlar band, and Vette Servo)
