2004 LQ9 + L92 Heads + LS3 Intake + Cam, Build Up
Old 11-17-2010 | 02:09 AM
  #91
67firebirdak's Avatar
Looks awesome in the pics but even better in real life!
Old 11-18-2010 | 06:06 PM
  #92
budhayes3's Avatar
PT's Slowest Truck
That mill looks right at home in there, keep up the good work man!
Old 11-20-2010 | 02:48 AM
  #93
matthew20061's Avatar
FIRST TEST START!!!
Everything sounded good, I need, new plugs and wires. The problem is I need one of those special custom make your own plug wire kit that will work with LS engines. So I can mount the coils down in the frame rails hidden away and run the wires back up to the plugs. Anyways here's some pics of it after I had just started putting the intake back on. I also got many harness modifications done and cleaned up a lot more wiring.
I've got a video of the first start up I'll post that later.
Old 11-20-2010 | 03:20 AM
  #94
Video is up!
http://www.youtube.com/watch?v=UXnMUGjGg8w
Old 11-20-2010 | 06:16 AM
  #95
Midnight's Avatar
Is that a bad ticking sound?
Old 11-20-2010 | 06:36 AM
  #96
budhayes3's Avatar
PT's Slowest Truck
I didn't hear anything "bad"...sounded pretty good for a first start up
Old 11-20-2010 | 07:57 AM
  #97
MGMC's Avatar
12 Second Club
sounds good man!
Old 11-20-2010 | 11:41 AM
  #98
skeet's Avatar
sounds really good man!! nicwe work and deffinitely a nice turnout
Old 11-20-2010 | 12:43 PM
  #99
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Sounds like you were starting to get the squeek I did with my LQ4, I just kept running it and it went away. It was rocker arms not getting enough oil so that rockers were squeeling on the valve stem. After a few minutes of idling it started to go away. Put about 1500 miles on it since with no problems.
Old 11-20-2010 | 12:48 PM
  #100
budhayes3's Avatar
PT's Slowest Truck
I actually did hear the squeaking, thought it was a belt noise...
Quick Reply: 2004 LQ9 + L92 Heads + LS3 Intake + Cam, Build Up
