2004 LQ9 + L92 Heads + LS3 Intake + Cam, Build Up
Old 11-21-2010 | 07:12 PM
  #111
james8997's Avatar
i just read through this whole thread and all i can say is WOW. great build. ill be doin something like this soon with my 97
Old 11-21-2010 | 07:47 PM
  #112
budhayes3's Avatar
PT's Slowest Truck
Originally Posted by matthew20061
The L92 heads will bolt right onto the 02 Escalade engine. You can use the stock L92 intake but since you said your putting it in a 02 Yukon that has drive by cable so you will have to get an adapter plate to use your stock throttle body on the L92 intake or buy a new 90mm cable throttle body with 4 bolt pattern to bolt onto the l92 intake. You would just use your stock MAF sensor. The heads do not have VVT. That is part of the cam and such in the newer motor the heads came off of. Hope my ramble makes a bit of sense.....
Actually, even though it is an 02, I believe it is drive by wire, as I was under the impression that all of the SUV's were drive by wire.
Old 11-21-2010 | 07:53 PM
  #113
1FastBrick's Avatar
Custm2500's Rude Friend
Actually, I believe it is drive by wire, as I was under the impression that all of the SUV's were drive by wire.
You sir are wrong and Ugly!!!
Old 11-21-2010 | 08:05 PM
  #114
1FastBrick's Avatar
Did you just use those adapter plates and run factory style rubber mounts when you did your LS swap???
Old 11-21-2010 | 08:29 PM
  #115
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Only traction control equipped
Old 11-21-2010 | 08:37 PM
  #116
1FastBrick's Avatar
Shhhh! Dont tell him 00-02 SUVs With TCS had DBW or hes gonna know they also switched to DBW as standard around 03 on the SUVS too....
Old 11-21-2010 | 09:42 PM
  #117
TXsilverado's Avatar
what was the painting process on the block? it wasnt a rattle can job was it? ill have my new LQ9 on the stand for a few weeks and would like to make it all purdy like yours...im more of a function over looks guy under the hood though so i dont want to spend too much money on looks.
Old 11-21-2010 | 09:50 PM
  #118
budhayes3's Avatar
PT's Slowest Truck
Actually, I'm wrong and purdy! (I've got a face that only a mother can love )
So only traction control...ahhh, I thought that it was all SUV's. Allrighty, I'll try to commit that to the memory bank lol!
*EDIT* I knew about the 03 switch though
Old 11-21-2010 | 09:56 PM
  #119
matthew20061's Avatar
The painting process for the block was:
1. Pressure Wash
2. Clean with DX330
3. Sand with 220, 400, 600, wet.
4. Clean and DX330
5. Prime with my Primer that goes to my PPG Paint for the truck (European)
6. Sprayed out 2 layers of the Copperhead PPG Custom paint.
7. Sprayed 2 layers of PPG (eqivilent) clear.
8. Done!
Definitely not a rattle can job, but the accessory covers where. 3 coats of rattle can High temp engine paint (gray) and high temp engine clear on those.
Old 11-21-2010 | 10:17 PM
  #120
budhayes3's Avatar
PT's Slowest Truck
Nice process, I didn't realize that you went through so much to make it look so good...I was already impressed with your work, now I'm totally and thoroughly impressed!
Quick Reply: 2004 LQ9 + L92 Heads + LS3 Intake + Cam, Build Up
