2004 LQ9 + L92 Heads + LS3 Intake + Cam, Build Up
#21
#22
I believe their has been multiple back to back tests with the LS3 intake ported and stock yielding no gain, but an actual loss with the ported LS3 intake. I'd either go FAST or keep the LS3 stock. The LS3 stocker does actually pretty good.
Thanks Skeet on the cam feedback on PTV. Figured he'd be fine, I was just throwing out a FYI as it can't hurt to check.
#23
#24
I pulled the heads off the LQ9 last night and everything looks great, cleaned the top of the pistons too. I'll get some pics up in a bit. I ordered new ARP Head Bolts, and ARP Stainless Intake Bolts as well.
#25
Here's what it looks like as of now!
Plan is to clean and sand the block, then prime and seal it and paint it Copperhead, the color of the truck. Should look good! I'm open to suggestions on painting other parts of the engine, I may want to find some nicer valve covers as I won't be able to run my Coil Covers with the LS3 intake.
#26
New ARP Head Bolts and ARP Stainless Intake Bolts Came in the mail today!!! Then I also got a call from the dealer and the L92 offset rocker arms and supports came in as well. Here's some pics:
#27
Do you already have the heads? i have a brand new set never used that im selling for 530$ shipped, they are bare ready to be assembled! love your truck btw i had a 68 before my new ride, just pm me if interested... subscribed
#28
Got in the injector pigtails for the LS3 injectors, the connector type is EV6/USCAR.
#29
UPDATE:
Painted the engine, the Copperhead color of the truck and it turned out looking awesome. Now I'm going to pull the oil pan, front cover, and valley cover and sand blast them and clear coat them! Should set it off a bit, if the bare clear coated aluminum doesn't look right I'll find a nice gray color for them.
Check the pictures out....
