2004 LQ9 + L92 Heads + LS3 Intake + Cam, Build Up
Old 10-26-2010 | 01:58 PM
  #61
ShredSled's Avatar
Originally Posted by matthew20061
If your running the L92 intake and rails, run a aftermarket regulator off the feed line and connect your return line to the regulator then run the regulated pressure to the rails. That's how mine works. You can also use a corvette fuel filter it has a return line and automatically regulates the pressure.
Thanks for the input. I'll look into that corvette filter/regulator further, do some searching on here or something and see what I can dig up. From what I understand now, I think I'll be trying to keep my return style fuel system, but still unsure...
Old 10-27-2010 | 08:37 PM
  #62
budhayes3's Avatar
PT's Slowest Truck
Looking good man, coming along nicely! I really like the color that you did the oil pan and covers in, nice compromise between black and aluminum
Old 10-28-2010 | 01:45 AM
  #63
matthew20061's Avatar
Thanks, I thought that color came out nice too! Can't wait to drop it in the truck...
Old 10-28-2010 | 02:04 AM
  #64
casper02's Avatar
real nice build thanx for sharing as for the return fuel system run a regulator form the valve on the rails and the regulator has a return ull just have to buy a couple of fittings hope that helps
Old 10-28-2010 | 09:19 AM
  #65
04BlackSilverado's Avatar
Originally Posted by ShredSled
seems I've heard a lot of complaints about the walbro 255...
Got 3 years and 40+k miles on mine, never had an issue.
Sweet build, good luck
Old 11-01-2010 | 12:56 AM
  #66
Thanks, the fuel system is already done fyi.
Thanks, glad to head the Walbro is reliable!
Anyone interested in the stock 317 heads or complete truck intake manifold?
Old 11-03-2010 | 06:06 PM
  #67
Ordered a Circle-D Converter 278mm, 3200 Stall speed. I'm guessing it should be here next week hopefully. After it gets here I'm ready to start pulling the 5.3L and replace it with the 6.0L!!!
Old 11-04-2010 | 12:12 AM
  #68
Latest pics, I just test set/fit the intake on there to see how it would look and dang!!!
Old 11-04-2010 | 12:37 AM
  #69
Dezert1500's Avatar
What water pump are you running? What are you doing about belt alignment? Spacing water pump? Swapping w/p pulleys? Relocating idler etc...
Old 11-04-2010 | 02:34 AM
  #70
I'm going to be running the complete front setup off of a corvette (It's already on the 5.3l). Brackets, Water pump, power steering, alternator, idler, crank pulley, and gaterback belt.
Quick Reply: 2004 LQ9 + L92 Heads + LS3 Intake + Cam, Build Up
