2006 5.3 lm7
2006 5.3 lm7
I have a 2006 CRew cab half ton with the 5.3. I am wanting to install a 2002+ ls6 cam in it and replace the springs with the comp cam 918's. curious if anyone has done this or ever seen the dyno #'s of this. I was told it would add up to 40+ rwhp.??? Not sure if i believe it or not, so thats why i am asking you guys. thanks for any help. casey
here the specs from my stock cam to the 2002+ ls6:
stock 5.3 lm7 cam
5.3 LM7
190/191 int/exh @ 0.05" duration
0.466" / 0.457" int/exh lift
114 LSA
2002+ ls6 cam
2002+ LS6 cam
204/218 int/exh @ 0.05" duration
0.551" / 0.547" int/exh lift
117 LSA
stock 5.3 lm7 cam
5.3 LM7
114 LSA
2002+ ls6 cam
2002+ LS6 cam
117 LSA
I posted a few links here regarding the LS6 cam. Scroll down and check them out:
https://www.performancetrucks.net/fo...d.php?t=392820
Any reason why you don't want to go with a slightly bigger/different cam?
I have the same truck and am looking for good reliable mods to do to mine also. I am in the process of searching the forums, but would like to know what results others have gotten from their 5.3's. What rear end do you have in your truck?
gaps
10-15-2015 02:53 PM
jtphelps289
09-01-2015 08:58 PM
grantpo
07-15-2015 12:21 PM
